Anyway of making the reverse camra clearer
Shaneyboi88
- 1st Gear
Is there anyway of making the reverse camera any clearer or a better camra or data ?? Thanks
Re: Anyway of making the reverse camra clearer
Not really other than making sure it's clean
It's the low resolution of the screen on the 2G MMi cars which need improving so even a better camera still wouldn't work. However the cost to retrofit a 3G MMi system with it's bigger better screen is over £1000 if you fancy doing that, I know a few people have.
Put your head closer to the screen.
Specsavers.
Shaneyboi88
- 1st Gear
It allready is the 3g mmi. Ill try giving it a good clean see if it changes.
If the lens is clean then the 3G MMi normally shows a very good image from the camera as it's virtually double the resolution of the 2G screen.
Are you looking at the head unit or the speedo?
Shaneyboi88
- 1st Gear
Head unit. Ill take a pic and upload it see if it is normall or if theres something wrong with it
Users browsing this forum: French, Google Adsense [Bot] and 294 guests
