Car feels like it's taking off goes all wobbly ??
D3855
Post by D3855 » Sat Nov 19, 2016 6:49 pm
Anyone else think with these rs6s that when u floor it from stand still the front end come up steering goes super light and u got to fight with it to keep in a straight line like the steering goes all wobbly ?
Re: Car feels like it's taking off goes all wobbly ??
Post by Ian_C » Sat Nov 19, 2016 6:54 pm
D3855
Post by D3855 » Sat Nov 19, 2016 9:27 pm
Many thanks for the links mate. Wow shocking! Just need to find a good wheel alignment place now
Post by MikeFish » Sat Nov 19, 2016 10:13 pm
I'd also check the front tyres for wear and check the pressures too. Has it only started doing it as the temperature has dropped?
D3855
Post by D3855 » Sat Nov 19, 2016 10:35 pm
It's got worse since having the wheel diamond cut.
It has 21" alloys... what pressure ment to be in them mate? It currently has 29psi
Markp
Post by Markp » Sat Nov 19, 2016 10:50 pm
[quote][/quote]
Too low. 2.4 and 2.7 bar from memory.
Post by Ian_C » Sat Nov 19, 2016 11:03 pm
D3855 wrote:Many thanks for the links mate. Wow shocking! Just need to find a good wheel alignment place now
Personally I'd recommend NOT going with Audis factory suggested figures - I'd remove the rear toe in, so the rear toe figure is zero. Will help make it go in a straight line when you nail it, cross cambers, white lines, cats eyes etc
viewtopic.php?f=76&t=122274&p=816756&hi ... ry#p816756
D3855
Post by D3855 » Sat Nov 19, 2016 11:13 pm
What's that in psi mate?
My mate who works in quick fit is Gona do the wheel alignment tomz!
It also has wheels spacers on!
Post by MikeFish » Sun Nov 20, 2016 12:03 am
Noooooo, don't go kwik fit if you want it done properly. Unless you really trust your mate I'd take it to a specialist.
And if you have adaptive cruise control they won't do it anyway.
wildbore
Post by wildbore » Sun Nov 20, 2016 8:06 am
Is this a serious thread? OP owns an 550bhp car and doesn't know the tyre pressures - and even worse has a pressure in them that is way too low but then asks a forum to provide diagnostics on handling issues.
Definitely get the tracking done before bothering to inflate the tyres, tighten the wheel bolts, hold onto the steering wheel with both hands, pay attention to the road, etc. Yep, it must be the tracking.
If the tracking doesn't fix it, blame the brand of tyres, the air suspension or Audi's designers, but not the tyre pressures.
Markp
Post by Markp » Sun Nov 20, 2016 8:51 am
wildbore wrote:Is this a serious thread? OP owns an 550bhp car and doesn't know the tyre pressures - and even worse has a pressure in them that is way too low but then asks a forum to provide diagnostics on handling issues.
Next question? How d'ya start it mate? There's no keyhole.
doodlebug
Post by doodlebug » Sun Nov 20, 2016 8:54 am
Sit on the key? Can be a bit uncomfortable.
D3855
Post by D3855 » Sun Nov 20, 2016 9:40 am
Bunch of wankers to the pointless posts if u don't no then don't post clearly don't no your self how much psi goes in them....I have had the car 3 days so ye getting use to it! Everyone's answers and via google for tyre pressures are all over the place 30s-45s! So it's not just me who doesn't no how much to put in them!
As for wheel alignment it's the 1st thing that everyone!! Says needs doing even when its brand new tons of posts with the same problems.
D3855
Post by D3855 » Sun Nov 20, 2016 9:43 am
MikeFish wrote:Noooooo, don't go kwik fit if you want it done properly. Unless you really trust your mate I'd take it to a specialist.
Crap really! He said there machines are 50k machines when I questioned him if they can do it properly. He Gona do it for free anyway so worth a try init.
wildbore
Post by wildbore » Sun Nov 20, 2016 9:54 am
D3855 wrote:Bunch of wankers to the pointless posts if u don't no then don't post clearly don't no your self how much psi goes in them....I have had the car 3 days so ye getting use to it! Everyone's answers and via google for tyre pressures are all over the place 30s-45s! So it's not just me who doesn't no how much to put in them!
On reflection, your approach to finding out tyre pressures is the right one. Although there is a label in my driver's door that tells me the correct tyre pressures and I could read it effortlessly whilst checking them on the car, I think it's much better to put down the tyre inflator, nip indoors, fire up my computer, join a forum, write a post and sit back and wait for someone to tell me the tyre pressures.
