B7 Milltek Non Res Centre Section
Post by HYFR » Sat Nov 19, 2016 7:34 pm
Used
Great condition
£100
:beerchug:
chriswhite1992
Re: B7 Milltek Non Res Centre Section
Post by chriswhite1992 » Tue Nov 22, 2016 1:50 pm
Any pictures mate?
Post by HYFR » Tue Nov 22, 2016 9:00 pm
its still on the car atm
hoping to swap out next week
Jerz165
Post by Jerz165 » Fri Nov 25, 2016 10:22 pm
Will these fit s4? Can they be used with stock system?
Post by HYFR » Fri Nov 25, 2016 11:23 pm
no idea ?
marc1
Post by marc1 » Sat Nov 26, 2016 7:39 pm
I would suspect so. You could do some research on Milltek's part numbers though Jerz and see if they are the same on the S4. Would also think you can get it to fit with the standard system too. Would just likely need to get some sleeves from an exhaust Shop which won't be much. Will make a good sifference in sand Ind on a stock exhaust though. Do it! :beerchug:
Post by Ian_C » Sat Nov 26, 2016 8:02 pm
Having swapped from a 4.2 res Milltek to non-res many years ago, I can confirm the exhausts are different bore:
S4 = 2.25 ich
RS4 = 2.36 inch
http://www.millteksport.com/exhaust.pro ... riantid=27
http://www.millteksport.com/exhaust.pro ... iantid=194
marc1
Post by marc1 » Sat Nov 26, 2016 8:17 pm
Good skills Ian. :thumbs: an exhaust place would have some reducers you could use to join them though.
Jerz165
Post by Jerz165 » Fri Dec 02, 2016 9:32 pm
Thanks for the advice chaps. I will look into it.
Post by HYFR » Mon Jan 02, 2017 4:51 pm
bump
Softishman
Post by Softishman » Thu Jan 05, 2017 10:50 pm
How much shipped to sweden?
@softishman on IG
Check out my RS4 there!
chuckrs4
Post by chuckrs4 » Thu Jan 19, 2017 12:19 am
Any chance this fits the standard exhaust once the original centres and cut out? Cheers
Users browsing this forum: No registered users and 81 guests
