RNS-E - fitted Bluetooth now have whine through speakers?
electricfurnace
- 1st Gear
Fitted a genuine Audi bluetooth kit to my RNS-E in my B7 RS4.
Works fine but I now have a whine through the speakers which increases on accelerating?
Any ideas? Harness was plug and play. Sounds like a grounding issue?
Re: RNS-E - fitted Bluetooth now have whine through speakers
Something tells me this has something to do with it...electricfurnace wrote: Pulled out stereo, located brown bose wire in pin 7 in green connector in quadlock.
Pulled out wire and grounded it a screw on back of head unit.
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
I had this a while ago & it was the amp that was causing the whine,try disconnecting it.
I disconnected mine & was gonna get a new one,but when I reconnected it the whine was gone,but it does come back from time to time.
B7 RS4 saloon,black,miltek,hi flo cats,MRC stage 2 remap,stage 2 manifold, CAF.
Previous,Z4m coupe,Tvr T350c,E46 M3 smg,R33 Nissan Gtr.
Bikes,Suzuki Gsxr 750,Kawasaki 600 ninjas.
electricfurnace
- 1st Gear
Dont think so as before i fitted the bluetooth but after doing the bose mod it was fine?harding wrote:Something tells me this has something to do with it...electricfurnace wrote: Pulled out stereo, located brown bose wire in pin 7 in green connector in quadlock.
electricfurnace
- 1st Gear
How do you disconnect the amp mate?obikaii wrote:I had this a while ago & it was the amp that was causing the whine,try disconnecting it.
Can you undo the bose mod?
electricfurnace
- 1st Gear
Yep just undone the bose mod, still whining
electricfurnace
- 1st Gear
Still whining! Really odd. Bluetooth harness issue maybe?
You can unplug the amp from the boot,its behind a removable pannel,drivers side,the lead has a red clamp that you need to unclip.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 117 guests
