Front discs & pads...
Markp
Re: Front discs & pads...
Post by Markp » Sat Nov 12, 2016 10:28 am
RS6chris! wrote:Outer "holes" on edge of discs are wear indicators for discs....once hole isn't visible anymore(worn down) this is indicating time for change.
Thanks Chris
Nigelo2
Post by Nigelo2 » Tue Nov 15, 2016 11:44 pm
For the Brembo wavy discs:
Front 19" dia: 36mm new / 2mm wear limit / therefore 34mm is the minimum thickness
Rear 17" dia: 22mm new / 2mm wear limit / therefore 20mm is the minimum thickness
hope this helps
