Porsche GT3 Callipers with RS6 drilled discs
2.7 V6 30v biturbo - 380 bhp
K2
Post by K2 » Fri Aug 12, 2005 2:03 pm
Just completed a brake conversion on my RS4 at approx half the cost of a Movit or AP conversion.
The callipers are Prosche GT3 six piston callipers as fitted to the present GT3 Cup race cars, the discs are stock RS6+ (same price as standard RS4 discs) and the pads at present are Pagid RS 421 Black, which give a very progressive peddle feel, and fantastic stopping power.
I would recommend this to anyone considering a brake conversion, its made the car completely different to drive.
RS4ever
RE: Porsche GT3 Callipers with RS6 drilled discs
Post by RS4ever » Fri Aug 12, 2005 11:53 pm
Total cost is?
Does everythinmg just bolt on the existing holes?
don
Post by don » Sat Aug 13, 2005 2:30 am
Very nice upgrade. :P
Excuse my ignorance but do the calipers bolt straight on?
I have noticed there is an abundance of porsche 6 pot and even 8 pot calipers on ebay that don't seem too expensive, anyone care to comment? Choice of colours too.
http://cgi.ebay.com/porsche-6-pot-brake ... dZViewItem
http://cgi.ebay.com/Porsche-6-Pistion-R ... dZViewItem
http://cgi.ebay.com/Porsche-6-Pistion-C ... dZViewItem
http://cgi.ebay.com/Porsche-6-Pistion-Y ... dZViewItem
8 pot:
http://cgi.ebay.com/ebaymotors/BREMBO-8 ... 8652QQrdZ1
K2
Post by K2 » Sat Aug 13, 2005 9:37 am
Cost:
Calipers £220 each
Discs £210 each
Pads £240 for the set
+ vat! :(
The calipers fit using a machined aluminium bracket, and the discs bolt straight on. The discs are 5mm larger in diameter than the standard solid RS4 disc, which the calliper can accomodate with ease. I'm not sure that the calipers on ebay are the same as they seem to have different different bolt holes to mine. If anyone is interested, I can forward the Porsche part numbers.
RSfource
Post by RSfource » Mon Aug 15, 2005 8:06 pm
Please send us the Porsche part numbers. Also, did you purchased the calipers thru the Motorsports Part Number? (From GT3 Cup cars)
Regards,
RSFource
K2
Post by K2 » Tue Aug 16, 2005 7:00 am
RSFource,
the road going part numbers are:
996 351 431 90 left side
996 351 432 90 right side
The race partnumbers are the same, as are the callipers i think. Mine were brought through a company who races and sets up porsche GT3 Cup cars, Parrs motorspport, www.parr-uk.co.uk/
Good luck with your conversion let me know how you get on.
RSfource
Post by RSfource » Tue Aug 16, 2005 6:50 pm
Thank you!
hataw
Post by hataw » Tue Aug 23, 2005 3:15 pm
where can i get the aluminum braket for the kit
HGH
Post by HGH » Tue Aug 23, 2005 10:10 pm
Are you sure the discs are RS6 , because on my car they won't fit
K2
Post by K2 » Wed Aug 24, 2005 9:45 pm
Quite sure,...
I saw them come out of the box, and fitted with no problem.
Are you fitting them with the standard callipers, as they are 5mm greater in diameter than the standard RS4 discs.
HGH
Post by HGH » Fri Aug 26, 2005 9:53 pm
I've already got RS6 callipers fitted on my car for 6 months, but i tried to fit
the RS6+ discs but they get stuck.
The difference between the RS4 disc and the RS6 is not only the diameter that's
no problem, the problem is the center, that's different in hight.
K2
Post by K2 » Sat Aug 27, 2005 9:43 am
What does your disc get stuck on?
When you say the centre, do you mean the off set of the centre of the disc rotor when compared to the centre line of the caliper, or do you mean the centre of the bell assembly.
kiwi_mtm
Post by kiwi_mtm » Wed Aug 31, 2005 7:59 pm
Do you use the original carrier ? (bracket that holds the caliper to the hub/strut)
HGH
Post by HGH » Wed Aug 31, 2005 8:48 pm
I use the original one's
K2
Post by K2 » Wed Aug 31, 2005 9:55 pm
kiwi_mtm wrote:Do you use the original carrier ? (bracket that holds the caliper to the hub/strut)
No. The original carrier was removed and replaced by a machined aluminium block allowing the brembo caliper to be fixed to the RS4 hub/ strut.
Users browsing this forum: No registered users and 6 guests
