They're not cobratrak 5. Hope that helps.LukasPukas wrote:My new car had a tracker fitted, which I did want to reactivate. However, I wasn't given any details, just two black fobs (which in turn don't have much in the way of details on them). Is there any way to work out what it is without phoning around (which given the comments about insiders above, I would hestiate to do)? What do Cobra fobs look like (given I think this the most logical).
Tracker Needed
Re: Tracker Needed
Current ride’s
Previous rides
Previous rides
- LukasPukas
Re: Tracker Needed
Cheers, I will have a word with Audi and see if they fitted one. Failing that I will have to try and contact the last owner and hope he responds.
Incoming... 2015 (C7 FL) RS6 Avant in Prism Silver
Gone... 2009 (C6) RS6 Avant in Phantom Black
Re: Tracker Needed
Lukas, they look like the fobs I had for my Tracker.
- LukasPukas
Re: Tracker Needed
That sounds like a good place to start, will give Tracker a shout. Thanksjezitalia wrote:Lukas, they look like the fobs I had for my Tracker.
Re: Tracker Needed
It's a transponder that you just keep on your person. No touch sensor or anything like that.jellyfloor wrote:A related question - not about where the tracker itself is located but how the fob sensor works on Cat 5 trackers (and where the sensor would be put). Is there a sensor somewhere you have to touch the fob to? Am getting a new RS6 and deciding on what to do about trackers - the fob aspect is putting me off a bit - dont really want it to mess up the interior if a sensor is needed.
Current ride’s
Previous rides
Previous rides
