Anybody have your drivers door feel like its dropped
Shaneyboi88
- 1st Gear
My drivers door feels like its dropped a little because when i shut it sometimes it dosnt shut properly and when you open it you feel it stick a bit. Dose anybody know if i can adjust it slightly and how i do it ? Thanks
Re: Anybody have your drivers door feel like its dropped
It's funny you should say this, I just remembered I had a dream last night where I had a white B8 S4 or RS4 and the passenger door had dropped a little. In my dream apparently this was a common problem with this car.
Not helping you much but thought I'd share.
I've just got home from an R32 meet where they were discussing this exact same thing - seems a common prob and to adj / fix, there a 1/2 inch bolt inbetween door hinges. - a slight adj, sorts. Obv I dunno if same for C6...but share just in case.
- RS6 London
- 1st Gear
Yup happened to mine just needs adjustment
Ive just noticed this on the b7 rs4 I have just purchased.
you can really lift it up and down compared to the others.
I hope it can be adjusted and its not the inner door pin worn which can also happen.
I think the cause is the weight in these doors these days puts a lot of stress on the hindges
Drive low,park lower
