Removing / polishing tail pipes
5.0 V10 50v biturbo - 571 bhp
Nosillad
Post by Nosillad » Thu Oct 20, 2016 9:46 pm
Wanting to see if I can restore some shine back to my oval tail pipes before forking out for some new ones, does anyone have any recommendations on something chemical that will remove what looks like a few years of blackening. Also can they be simply removed to make the whole job a little easier.
Basically I'm just twiddling my thumbs before it goes off to unit20 for all the mechanicals and I need a project. :roll:
Thanks Craig
2008 Phantom Black RS6 Avant
2018 Volvo XC60
Previous- 996 C4S, E60 535d, E60 M5, E46 330i, B7 S4, Imprezza Sti PPP, R32 GTR.....
Jim Haseltine
Re: Removing / polishing tail pipes
Post by Jim Haseltine » Thu Oct 20, 2016 10:19 pm
If you're not scared of using a bit of the old elbow grease, Autosol*.
*Other metal polishes are available
Woly64
Post by Woly64 » Fri Oct 21, 2016 4:45 pm
I used a whole series of Bilt Hamer wheel cleaner/gunk/petrol all with different grades of wire wool finishing off with a fine grade and some Autosol. Plished everything up with a combination of a shaped dome polisher on my drill together with mt I ended up using a very fine grade wire wool to get everything off the outside and inside. Polished them up using a cone shaped polishing head on my drill and the Dremmel for the awkward places. Came up a treat
Currently floating along in a 2020 Magnetic Grey Bentley Continental GT & bouncing around in a Navarro S3 black edition
2009 C6 Avant NR Milly, MRC Stage 2/gearbox, MTM 21'' bimotos, H&R arb's, KW coil overs, 756ps & 1085 Nm (now in Simon’s safe hands)
C5 RS6+ No 315 in Metallic Silver (gone but never to be forgotten)
S8 V10 awesome engine but taxi-like gearbox - had to get back to RS motoring
C5 RS6 in Avus Silver - the 1st RS experience
A20LEE
Post by A20LEE » Fri Oct 21, 2016 5:18 pm
Try oven cleaner to break down the carbon. I wouldn't recommend autosol or wire wool unless they are in pretty bad shape as they do scratch.
Nosillad
Post by Nosillad » Fri Oct 21, 2016 7:30 pm
Thanks guys, have you done then whilst on the car or can you remove the tail pipes on their own?
2018 Volvo XC60
IanH755
Post by IanH755 » Fri Oct 21, 2016 9:48 pm
OEM is part of the back box and can't be removed- aftermarket is usually bolt on and can be removed.
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
Nosillad
Post by Nosillad » Fri Oct 21, 2016 10:47 pm
:D It's OEM so that's just saved me 1/2 an hour of swearing whilst trying to work it out thanks
2018 Volvo XC60
Jim Haseltine
Post by Jim Haseltine » Sat Oct 22, 2016 10:19 am
Its an Audi - 1/2 an hour swearing is for easy jobs like topping up the washer fluid or changing wiper blades.
IanH755
Post by IanH755 » Sat Oct 22, 2016 12:58 pm
Proper swearing is for apparently "non-essential" roadside stuff like head light bulbs etc :audibash:
MNK
Post by MNK » Sat Oct 22, 2016 7:20 pm
Fine wire wool, Meguiar's NXT Metal Polish and they'll be looking brand new.
gorwanvfr
Post by gorwanvfr » Sun Oct 23, 2016 10:42 am
Believe it or not but tin foil and water. I use it all the time for the chrome on my classic cars.
RS6 C6 (Gone but not forgotten)
Golf R
Delorean DMC 12
Jaguar MK2
E-type
Jim Haseltine
Post by Jim Haseltine » Sun Oct 23, 2016 10:56 am
We use the same method to remove light cigarette burns from the finish on wooden furniture.
longman h
Post by longman h » Sun Oct 23, 2016 10:17 pm
gorwanvfr wrote:Believe it or not but tin foil and water. I use it all the time for the chrome on my classic cars.
Never knew that but will definitely be giving it a go.
Thanks for the tip.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Nosillad
Post by Nosillad » Sat Nov 05, 2016 9:43 pm
Well after trying most of the above I think the tinfoil and water got the best results, well worth a try if anyone else wants to take on the same task.
Thanks Gorwanvfr :thumbs:
2018 Volvo XC60
Farravi
Post by Farravi » Mon Nov 07, 2016 6:29 pm
Woly, that's quite a finish you have achieved, nice
Users browsing this forum: No registered users and 55 guests
