Newbie questions
ahoooga
Re: Newbie questions
Post by ahoooga » Mon Oct 17, 2016 10:11 pm
Shoppinit wrote:^yup, that's a switch. Couldn't you find a lowered one?
/lol
:beerchug:
TechNick
Post by TechNick » Mon Oct 17, 2016 10:22 pm
2. It's been a long time since I last repaired/replaced mine, but seem to recall that holding down the eject button for several seconds will 'force' an eject of the cartridge (provided it's got power etc.).
From memory, it will normally try to return the current CD back into the cartridge before ejecting it, but if said CD is stuck (e.g. the roller can't grip it properly), then the whole eject process can't complete.
The force eject just spits the cartridge out regardless, leaving the stuck CD in (but you can then normally fish it out through the gap left by the cartridge).
Regardless, you'll probably want to stripe it down and clean all the mechanisms anyhow, and I don't remember it being particularly difficult to remove/take apart, so no real biggie.
Sent from mobile with fat fingers
Post by bam_bam » Mon Oct 17, 2016 11:23 pm
I haven't found a way of ejecting it without power...that's where I'm at.
TechNick
Post by TechNick » Tue Oct 18, 2016 7:33 am
Don't know if of any use, but found this... http://www.audiworld.com/tech/elec4.shtml
Bradders911
Post by Bradders911 » Tue Oct 18, 2016 8:02 am
I seem to have power as a little orange light glows inside the mech when I press the eject button. Holding it down hasn't helped.
The Nav Plus and CD changer will both be coming out when I find a decent replacement head unit that doesn't look too Halfords.
Post by bam_bam » Tue Oct 18, 2016 9:08 am
TechNick wrote:Don't know if of any use, but found this... http://www.audiworld.com/tech/elec4.shtml
V.Helpful. I'll be trying this at the weekend innit.
Bradders911
Post by Bradders911 » Tue Oct 18, 2016 12:28 pm
Worked 1st time, thank you !!!!
Just used a bit of folded card 6cm x 10cm and slid it all the way under the CD cartridge and out it popped. Put it back in and it stuck again, but the card got it out second time too.
TechNick
Post by TechNick » Tue Oct 18, 2016 1:17 pm
Cool. Is it possible there was a 'round left in the chamber' when you ejected the cartridge?
If so, then pressing the eject button again with no cartridge inserted may be enough to get that CD out.
Either way, you'll probably want to clean the inners of the unit (and the CDs!) to help prevent it happening again.
nzrs6
Post by nzrs6 » Tue Oct 18, 2016 8:27 pm
my car came with a switch that looked just like that. the old owner had laser jammers fitted.
Bradders911
Post by Bradders911 » Tue Oct 18, 2016 8:45 pm
nzrs6 wrote:my car came with a switch that looked just like that. the old owner had laser jammers fitted.
Wahay. Now where should I look for a laser jammer on the RS ?
:biggrin3:
Bradders911
Post by Bradders911 » Tue Oct 18, 2016 8:46 pm
TechNick wrote:Cool. Is it possible there was a 'round left in the chamber' when you ejected the cartridge?
Unfortunately no left over cd. Safe to say the changer is toast.
nzrs6
Post by nzrs6 » Tue Oct 18, 2016 10:50 pm
I have two little black boxs in the lower grill that are the transmitter units. I am unsure what brand mine is but when switched on there is a loud beep To inform me it's running
Bradders911
Post by Bradders911 » Wed Oct 19, 2016 8:26 am
nzrs6 wrote:I have two little black boxs in the lower grill that are the transmitter units. I am unsure what brand mine is but when switched on there is a loud beep To inform me it's running
Thanks. I have a look for some transmitters. I dont think Ive pressed the button with the car running, but I'll give that a go when Im out later today. I wonder if its a nitrous switch :biggrin3:
Daveperc
Post by Daveperc » Wed Oct 19, 2016 9:46 am
I have my "parking aid" transmitter mounted in the front grille just above the number plate.
I have mine wired using the "spare" switch slot in the dash (well it's spare as long as you don't have the electric rear window blind). The switch kills the system - the reset button... well I'm not saying where that is.
Dave
Bradders911
Post by Bradders911 » Wed Oct 19, 2016 2:24 pm
No transmitters in the obvious places and the switch seems to do nowt.......
I'll ask the dealers to ask the previous owner what the switch is for.
Users browsing this forum: philS2 and 115 guests
