Possible RS2 Buyer...help anyone??
If the chip is the actual problem, you could always just get a new chip fitted that isn't "encoded" rather than a whole new ecu, which should allow you to to use VAGCOM as well as being cheaper.
Talk to the MRC boys - http://www.mrctuning.com/
or failing that s2central on the S2 Forum may be able to help.
You could go back to standard or depending on the cars set up possibley get the same or a bit more out of it. I know what I would do.
I had the same VAGCOM problem from a old mapped chip and since it was remapped (and the chip was replaced) by MRC, VAGCOM works just fine.
Angus
Angus
RS2 +
Users browsing this forum: No registered users and 46 guests
