2000 S4 Running Sluggish (well, in relative terms)
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Zen
Post by Zen » Sun Aug 07, 2005 3:06 am
Noticed over the past 6-8 wks the surge in power that used to happen at 2000 revs doesn't now occur until about 3000-3500 revs. The oil temperature also seems to be a little higher than what I remember.
I checked for fault codes with VAGCOM and the following turned up:
16502-Engine Coolant Temp Sensor (G62): Signal too High
P0118-35-10----intermittent
I then logged block 003 to redline:
Time stamp, Eng speed, MAF, Throttle Angle and Ignition Timing:
495.49 3600 066.81 22.0 27.80
496.40 4000 109.44 34.1 22.50
497.34 4520 107.14 27.1 17.30
498.31 4840 084.33 21.2 17.30
499.31 5040 077.44 20.0 30.80
500.32 5160 056.97 16.9 35.30
501.34 5200 048.83 14.9 37.50
502.37 5240 037.89 12.9 41.30
503.39 5320 082.11 20.8 31.50
504.44 5560 069.33 18.8 33.80
505.51 5880 117.92 27.1 27.80
506.63 6440 149.81 38.4 28.50
507.76 6840 115.75 25.5 07.50
The mass air flow readings appear to be very low. I note from other posts that ideally I should log from 2000 revs right up to redline with wide-open throttle. Does WOT mean completely flooring it from 2k revs rather than doing a controlled, gradual acceleration?
Zen :(
Zen
RE: 2000 S4 Running Sluggish (well, in relative terms)
Post by Zen » Sun Aug 07, 2005 2:42 pm
A search for the above fault code revealed this:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-00 --
Readiiness 0010 0101
The symptoms of this small device are varied and wide:-
It can cause the ecu to cut back on boost,
It can cause soft limp mode and poor running.
It can make you feel you have a boost leak and
It can provide false reading that could cause lean or rich running.
It could cause strange dash temperature readings.
It is quite surprising how varied and dramatic an effect this sensor can have.
http://www.waheedkhan.com/tempsensor/tempsensor.htm
Looks like I'll need to book in for a replacement sensor.
S2tuner
Trader (Expired)
Post by S2tuner » Sun Aug 07, 2005 6:40 pm
Zen, your MAF log isn't right as you weren't wide open throttle, and without WOT you can't gauge if the sensor is bad or not...
You have to press the throttle all the way at 2k and keep it there to 7k....
HTH,
Mihnea
Zen
Post by Zen » Sun Aug 07, 2005 7:28 pm
Thanks Mihnea... just preparing to go out for another couple of runs....
Zen
Revised VAGCOM logs
Post by Zen » Sun Aug 07, 2005 9:28 pm
OK. WOT in 3rd:
Columns are time stamp, revs, mass airflow, throttle angle% and ign timing.
654.32 1840 058.58 074.9 13.5
655.24 2200 081.81 087.1 13.5
656.14 2600 112.28 100.0 09.8
657.05 3040 130.67 100.0 12.8
657.95 3480 147.25 100.0 13.5
658.86 3920 157.33 100.0 12.8
659.78 4280 166.42 100.0 14.3
660.73 4680 178.42 100.0 14.3
661.73 5040 185.00 100.0 18.0
662.75 5400 193.36 100.0 18.8
663.81 5680 194.67 100.0 18.0
664.90 6000 194.75 100.0 23.3
666.01 6280 201.25 100.0 23.3
667.14 6560 202.86 100.0 24.0
668.26 6800 206.31 100.0 29.3
669.40 6800 075.28 019.6 27.0
Block 003 presented above but I also logged blocks 001 and 002 at the same time. Did three different runs and all registered max airflow of 206.
Zen
S2tuner
Trader (Expired)
RE: Revised VAGCOM logs
Post by S2tuner » Sun Aug 07, 2005 10:04 pm
your MAF looks ok-ish to me... a little bit on the low side, a new one would do around 212g/s peak but it's not too bad still... Try disconnecting it and see if it makes any difference...
audiboy
Post by audiboy » Sun Aug 07, 2005 11:42 pm
Coolant temp sensors fail for a past time on loads of VAG engines. I would just buy a new one for 19 quid plus a new seal. They often give that error code. Like what was posted earlier. They can make the ECU pull back the boost.
Fit new sensor, top up lost coolant, clear DTC's,and try again.
Tom C
VW Golf Mk2 2.0T 20VT, GT3071R, FMIC, Hi-spec brakes, 4xxbhp MRC Mapped
B5 RS4 - RS6 hybrids, FMIC, 520bhp MRC Mapped
VW Golf Mk4 20VT, K04, AP brakes, 260bhp - SOLD
Bluebrakes
Post by Bluebrakes » Sat Aug 23, 2008 3:45 pm
Address 01: Engine
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 01972
1 Fault Found:
P0118 - 35-10 - - - Intermittent
Readiness: 0000 0000
I have the same fault. Although I shall change the sensor, does anyone know what the peak boost should be on a standard s4?
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Aug 23, 2008 6:14 pm
0.7 to 0.8 peak
http://www.MRCtuning.com
Users browsing this forum: Bing [Bot] and 91 guests
