Suspension noise
Re: Suspension noise
What do people recommend replacing the system with. Are Bilsteins best?
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
Seattle-squash
Suspension noise
For all around use they are had at a very good price, but different people will have a different take obviously. I installed the Pss9's a year and a 1/2 ago and think they been great. Adjustable height is almost worth it for itself plus dampening adjustment. I think if you track you might go the KW - V3's, not a big difference in prince when I got them, only a few hundred $. My assumption is that your reference to the whole systems implies full coil-overs.
I had the same issue, the front DRC pipe had split and all the fluid was pushed out. Everytime I went over a bump the knock came from the back when the issue was at the front. Pipe was about £110 and the DRC filling and pressurising was £150 ish as the machine had to be rented in
RS4 Cabriolet - Phantom Black with Exclusive interior
Bilstein b14 was recommended to me. There's so many bloody options. I'm thinking of trying to look for replacement shocks with the drc and keeping the standard springs. Anyone else done that?
audi_do_dat_den
Yep, i did just that.
Couldnt be happier with the DRC system. Its far and away a superior set up than any fixed coil-over upgrade.
I had a rear shock fail recently, made some horrible clanking and thumping while i hobbled around.
Had both rears changed and a full system recharge, and i love it.
Comfortable ride and acts like it should when throwing into corners.
Users browsing this forum: Google [Bot] and 322 guests
