What's the lowest and safe voltage for dashcam to shut ?
CaptainLeadFoot
Post by CaptainLeadFoot » Fri Oct 07, 2016 3:49 pm
I'm going to have the Thinkware F770 installed tomorrow, just want to make sure I do not drain the battery too much.
Thanks !
audi_do_dat_den
Re: What's the lowest and safe voltage for dashcam to shut ?
Post by audi_do_dat_den » Fri Oct 07, 2016 8:47 pm
I could be wrong, but i think you will find that the dashcam set up is normally better hard-wired to the ACC or switched power supply, and the camera itself will automatically start recording as per its own set schedule while powered up.
If you were planning to have it continuously recording even when the car is parked up, then you may face battery drain issues if left for an extended period.
It will be low current draw, but its still not the best setup.
Post by Ian_C » Fri Oct 07, 2016 11:17 pm
This is how I've wired our family cars. Hard wired into the fuse box so they come on with the ignition. I just bought some spare cigarette lighter sockets, positive into the fuse box, negative earthed on the chassis. You need to pick a circuit that only goes live with the ignition - I think I did our Audis off the rear wiper fuse. Hide the cigarette lighter socket behind the dash, plug the dashcam into that
FaisalJ
Post by FaisalJ » Sat Oct 08, 2016 12:20 am
Voila
https://www.blackvue.com/power-magic-pro/
I think mine is set at 12v
2007 RS4 B7 Avant
pule333
Post by pule333 » Sat Oct 08, 2016 12:23 am
Mine is set at 11.8V or 12hours for Parking mode.
Using Mio MiVue 658 dash cam with wired smartbox power supply.
Never have problems with discharging the battery
RS4 B7 aka Vinnie
CaptainLeadFoot
Post by CaptainLeadFoot » Sat Oct 08, 2016 8:18 pm
Thanks guys.
The Thinkware F770 has internal shutoff so I don't need to put a powerbox. I asked a few times and the Shop insisted there's no need to install a backup battery so I just set the lowest voltage to 12.3V. It seems to start at 12V with no trouble but I'll play is a bit safer.
Users browsing this forum: Google [Bot] and 377 guests
