Jit's RS4 OEM Plus build
J1TVV
Re: Jit's RS4 OEM Plus build
Post by J1TVV » Mon Aug 29, 2016 10:35 pm
Hi All,
Only a few updates, had the brake calipers painted red, can't believe how big the front brakes are! In black very understated.
The best mod so far, middle box delete and x pipe installed can not believe how much better it sounds!! Lovely burble and some rasp at the top end of the Rev range highly recommend this.
Having the clutch done tomorrow by CAMSPEC.
Jit
2016 RS3 8V
2007 RS4 B7 Cabriolet Gone
Starry
Post by Starry » Mon Aug 29, 2016 10:56 pm
Brakes look good, as you said, black really doesn't do them justice..
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
Harris.
Post by Harris. » Tue Aug 30, 2016 11:43 am
Looks really good . who did your brakes for you and how much and the exhaust ? Pm if you prefer
Seattle-squash
Post by Seattle-squash » Wed Aug 31, 2016 12:12 pm
Very sharp, and like the red calipers. You might want to consider the RS caliper plate for the rear which makes a huge esthetic difference. On this side, ECS sells it under RS7 parts for example.
J1TVV
Post by J1TVV » Fri Sep 02, 2016 8:16 pm
Harris. wrote:Looks really good . who did your brakes for you and how much and the exhaust ? Pm if you prefer
Thanks!
Exhaust was done by EMP Performance and it was £250 all in. I am really loving this mod! She sounds amazing!
http://www.empperformance.com
The calipers were done by Specialist Tyres, a guy called Faz runs the place, I supplied the decal, the finish is really good, all 4 calipers done for £250 all in.
http://www.specialisttyres.co.uk
Cheers.
Jit
2016 RS3 8V
J1TVV
Post by J1TVV » Fri Sep 02, 2016 8:17 pm
Starry wrote:Brakes look good, as you said, black really doesn't do them justice..
Thanks mate.
Jit
2016 RS3 8V
J1TVV
Post by J1TVV » Fri Sep 02, 2016 8:20 pm
Seattle-squash wrote:Very sharp, and like the red calipers. You might want to consider the RS caliper plate for the rear which makes a huge esthetic difference. On this side, ECS sells it under RS7 parts for example.
Thank you mate, I did think about them, just not keen on drilling holes in the calipers! They do look good though.
Jit
2016 RS3 8V
AviatorEGHH
Post by AviatorEGHH » Thu Sep 22, 2016 7:45 am
Hi Jit,
Did you have the clutch done?
I have exactly the problem you've described and I've had the pipe changed. All I got was a heavier clutch pedal and the slow return after heavy acceleration is still there!
I can't for the life of me find any one around or on the internet that actually knows how to cure this issue.
I hope you have solved it and can let me know the answer. Cheers Buddy.
I'm more of an Avant man but yours looks nice ;)
Sprint Blue B7 RS4 Avant, new clutch, DMF, a Milltek, carbon clean, new front shocks.
Last car, B5 S4 Avant, Milltek, Stage 1.
J1TVV
Post by J1TVV » Thu Sep 29, 2016 8:26 pm
I did have it done, it's so much better know it won't stick down after you've it the beans!!
had the following done :
Clutch
Release bearing
Pressure plate
DMF
Slave cylinder
Master cylinder
Rob's braided updated pipe.
Problem solved, I got the LuK clutch kit, Sachs master and slave cylinder when Euro's have the 30% off deal they were less than £160 all in DMF is expensive and the labour!
Hope you get it sorted soon!
Jit.
Jit
2016 RS3 8V
marc1
Post by marc1 » Thu Sep 29, 2016 9:53 pm
AviatorEGHH wrote:Hi Jit,
Did you get a teflon lined, braided clutch pipe or a standard Audi pipe?
AviatorEGHH
Post by AviatorEGHH » Thu Sep 29, 2016 10:11 pm
I got the updated Audi pipe. I'm hoping the new one is ok considering the bad one took 65,000 miles to deteriorate.
I have a feeling there is more to it than just the pipe. There are too many unusual symptoms. Varying bite point after heavy acceleration, jumpy pull away when the car is cold, immediate bite after heavy acceleration (not nice and gradual). It's all too weird.
maars
Post by maars » Fri Sep 30, 2016 6:44 pm
Exhaust looks good. Any video clips?
Badman
Post by Badman » Sat Oct 01, 2016 12:10 am
:biggrin3: Video clip would be good!!
J1TVV
Post by J1TVV » Sun Dec 04, 2016 9:27 pm
No sorry not got any sound clips, but will try and get some.
Recent updates, I had the chrome vinyl wrapped as the chrome has always bothered me.
Rear lights also tinted
Front headlights also tinted but wasn't keen after these pics have removed the film
Jit
2016 RS3 8V
jaysrs4
Post by jaysrs4 » Sun Dec 04, 2016 10:32 pm
Looks lovely. I assume optics wasn't available on a cab? Always thought one would look good with black.
Users browsing this forum: Google [Bot] and 132 guests
