Bleeding ABS pump
jonytek
Bleeding ABS pump
Post by jonytek » Thu Sep 22, 2016 2:42 pm
So long story short I pushed air through the brake lines while bleeding them and now there zero pressure. I've been informed that the ABS pump may need bleeding. I just spoke to AMD and they seem to think I'll be fine with just bleeding the lines again and no need to do the pump - I don't have Vagcom.
Has anyone been through this before??
BUILD THREAD
IG: @bad_rs_4
skywriter
Re: Bleeding ABS pump
Post by skywriter » Thu Sep 22, 2016 6:28 pm
are you bleeding them in the correct sequence?
pule333
Post by pule333 » Thu Sep 22, 2016 6:43 pm
Hmm that is a strange advice from AMD. I always thought once the air gets inside the Pump, the only way to pump it out is use Vagcom to circulate the pump.. they might know something we don't. The only problem is that brake fluid is not cheap. So you could try doing it again but if doesn't work you are left with no fluid again.
RS4 B7 aka Vinnie
jonytek
Post by jonytek » Thu Sep 22, 2016 7:18 pm
pule333 wrote:Hmm that is a strange advice from AMD. I always thought once the air gets inside the Pump, the only way to pump it out is use Vagcom to circulate the pump.. they might know something we don't. The only problem is that brake fluid is not cheap. So you could try doing it again but if doesn't work you are left with no fluid again.
That's right. And no car to go pick up more fluid. I was thinking of ordering more off amazon. I might have look now.
But yeah, Amd said you don't need to do the pump on the B7. That's why I was asking, everywhere online says you need vagcom.
BUILD THREAD
IG: @bad_rs_4
jonytek
Post by jonytek » Fri Sep 23, 2016 12:59 pm
So no one else has ever messed up and pushed air through the system?? That's embarrassing.... :oops:
BUILD THREAD
IG: @bad_rs_4
audi_do_dat_den
Post by audi_do_dat_den » Sun Sep 25, 2016 12:59 am
Oh ive done it..... all too easy if you dont keep your eye on the resevoir level when bleeding.
The only way to free the trapped air in the pump housing is by running the ABS pump manually via Vagcom/VCDS during bleeding.
Even a microscopic amount of air will shag your chances of a firm pedal and you will also get an ABS & ESP warning light up.
irn_bru_ce
Post by irn_bru_ce » Sun Sep 25, 2016 2:27 am
On my old car, which had a bosch ABS pump, the general advice was to try skidding in a sand car park to bleed the ABS pump, not sure if that would work in the audi though
jonytek
Post by jonytek » Mon Sep 26, 2016 5:27 pm
Just in case anyone finds this useful in the future. I managed to sort the issue by simply rebleeding, this time getting the Mrs to hit the brake pedal while I opened the nipples. The pressure bleeders running 10-15 psi don't seem to have enough pressure to really push trapped air through the system... There was no need to bleed the ABS pump, well not for me anyway.
Anyway all good, i'm back out on the road... :blackrs4: :blackrs4:
BUILD THREAD
IG: @bad_rs_4
Post by chunky79 » Mon Sep 26, 2016 7:30 pm
So you didn't need the cable in the end then. For the cost of one, they're are great buy!
jonytek
Post by jonytek » Mon Sep 26, 2016 8:21 pm
chunky79 wrote:So you didn't need the cable in the end then. For the cost of one, they're are great buy!
I didn't mate but thank you.
BUILD THREAD
IG: @bad_rs_4
Users browsing this forum: Bing [Bot] and 67 guests
