F/S B7 Space Saver Wheel
Had this as a spare for B7 RS4 instead of the puncture repair kit. Note fits on rear only
£80 posted
£80 posted
Re: B7 Space Saver Wheel
Need this gone
£50 posted or it gets binned at the weekend
irn_bru_ce
is the centre the correct 57.1mm or 66.6mm?
Bore looks to be about 68mm.
Part number is 8K0 601 027D if this helps.
Re: F/S B7 Space Saver Wheel
as long as the centre bore is same or bigger and pcd/offset is correct it wont matter for a spare-its only to limp you to a tyre Shop after all...
Correct Arthur and it does fit on the rear of a B7 - trust me
Pistolpete2543
Hi Ian, would the posted price include Northern Ireland?
Yes that won't a problem - as long as it's less than £50 which I'm sure it will be
Pistolpete2543
Sounds good, you have PM.
