Fuel
Fuel
Hi all
I'm new to the forum and don't as yet have an S4 but hope to be out shopping soon. I've noticed that alot of you are using 98 octane fuel. I realise that this gives more performance but is it really nesessary? I currently have a 4.3 TVR that was built to run with 98 but has since been chipped and tuned to run 95. Still goes fast enough for me...
Mark
Mark
RE: Fuel
If you're the type of person who admits something is fast enough for them then 95 would be ok... but most people aren't, and the manual recommends 97/98. There is a difference, but it's not like it's sluggish on 95.
2000 Nogaro S4 Saloon
RE: Fuel
I doubt that the TVR ECU's are half as clever as the latest Bosch units in the S4/RS4 (well, all of the Audi range, in fact). They can adjust themselves based on the quality of the fuel, which does make a noticeable difference. Yes, the TVR may be fast, but I bet you have triple breakdown cover and it must be hairy in the wet
Re: RE: Fuel
I must admit that the TVR ECU is not as advanced as the Audi. It doesn't control ignition so can't <beep> the ignition when needed. The problem I had using super was finding the stuff and with a fuel tank that only lasts for about 130 miles its a regular searchNeilMc wrote:If you're the type of person who admits something is fast enough for them then 95 would be ok... but most people aren't, and the manual recommends 97/98. There is a difference, but it's not like it's sluggish on 95.
tartan_rob
RE: Re: RE: Fuel
The S4 was developed for 98 RON. As you know, the ECU will automatically <beep> timings for 95 RON with consequential loss of engine performance. If you're happy with this then fine, but why buy a performance car if you're going to intentionally <beep> that performance?
There again I see you've done this with your existing car, so go ahead...
2001 Silver S4 Avant
RE: Re: RE: Fuel
With the TVR the higher octane gave little differnece in performance. They did it to make up for poor mapping from the factory, they often over fueled. A car with a bestoke fuel map and an advance curve for 95 runs better than standard from the factory.
If the car can adapt for the fuel it's using currently then that is good. I don't see the point of burning or worrying about sourcing 98 RON fuel every day driving but is a nice boost for track day fun.
Seat of the pants can you actually feel a big difference between the fuels in use? Can 10 or 20 hp be felt in a 300 BHP car?
Mark
RE: Re: RE: Fuel
Hard to believe, but I can feel the difference. It's not so much top-end power (is it ever in the S4?), but mid-range pull - there is definately more urgency and a crispy throttle to boot.Seat of the pants can you actually feel a big difference between the fuels in use? Can 10 or 20 hp be felt in a 300 BHP car?
Oh, and I get better fuel economy with Optimax too.
Nige.
RE: Re: RE: Fuel
Its the mid range where the largest amount of ignition <beep> would be needed for lower octane fuel so more torque rings true...
Mark
RE: Re: RE: Fuel
I definetly got better economy with any of the 'super'. Since turbo swap run optimax almost all the time. Works out to about the same price with the extra mileage per tank.
RE: Re: RE: Fuel
Had my remapped B5 S4 Avant on the rolling road running BP Ultiomate and it was pushing out 312bhp and 375lb/ft torque. I took it back again a while ago running Optimax and was then at 326bhp & 389lb/ft torque. I know some slate Optimax but locally mine appears to be pretty good.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
I can definately feel the difference between optimax and unleaded. I recently took my car on a run to Newcastle. I filled up with normal unleaded on the way and optimax on the way back....
The car was more responsive and better (mpg) using the optimax, it just didn't feel the same while it was running on normal unleaded.... imo....
This subject has been brought up before, maybe worthwhile having another look at the thread..........
http://www.rs246.com/index.php?name=PNp ... light=fuel
Users browsing this forum: Google [Bot] and 87 guests
