Rocker cover removal
Hi all, i would like to remove my rocker covers to replace the bolts that hold them on, as a lot of them have gone quite rusty... can anyone tell me if this is an easy task to do, or am i going to need to remove anything complex... Also, thinking of renewing the coil packs and spark plugs whilst i do this.
Chris
Chris
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Re: Rocker cover removal
i looked into this you could swap them one at a time to save removal
however i the bolts were stupid money like 2 quid each maybe more i seem to remember it was nearly £90 to do them
There is a second part to the bolts that would drop into the engine if you just un-do them and pull them out...
Nothing will drop in its a m6 bolt with a washer on it
just pop a couple out measure the length then order a2 stainless of the net or local supplier and change one at a time. no need to remove covers!
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
I can't work this out, as i have purchased a set of new rocker cover bolts from audi, and there is a capture washer that would go on the inside of the rocker cover... I tried removing the bolts one at a time previously, but they wont pull out due to being locked through on the opposite side
They should just pull out
i Must be doing something wrong then, as i can't seem to pull them out, and a well known specialist also confirmed to me that the rocker covers needed to come off to replace them, and one of the rocker cover gaskets is only available with the rocker cover at a cost of over £300... or am i just having my pants pulled down again...
Did this get solved? Also what was the part number for the bolts? And torque specs - 10 Nm (7 ft lb)?
They did just pull out, but were a pig to get out as the rubber seal on them holds tight to the rocker covers. After being told by a reputable specialist that the rocker covers needed removing as the screws to hold them on were secured on the other side of the rocker cover and i'd need new gaskets at the cost of over £300 was a complete lie. I cant remember the part number for the screws, but ordered them from TPS, and they come with the rubber seal attached.
thread revival
ok, so whilst renewing spark plugs, broken coil pack connectors and rocker cover valve gasket .. I also have the envious task of changing some of the rusted rocker cover torx bolts.
You would think they should slip out 'fairly' easily.. but they're really stuck in there.
Knowing how old and likely brittle from years of engine heat the rocker covers are.. I'm little apprehensive of causing damage to the covers - as they're not cheap!
Anyone know of the procedure / trick of replacing some of the rusted rocker cover bolts.. ?
ok. scratch that.
managed to get some out... applied some wd40.. and .. waited.
then very carefully pushed them through from underneath (using hands only, not easy)
Will update with pictures once all done and cleaned up.
fyi. Genuine Audi Hexagon collared bolt with guide sleeve
Part # 03G128773A
Part # 03G128773A
cleaned up nicely.. with general 'elbow grease' spray..
would have been nice if Audi supplied the replacement rocker valve cover bolts in black
to match with existing ...
anyway, just carefully painted bolt heads in Hammerite black.
Users browsing this forum: Google [Bot] and 94 guests
