Led rear lights
Led rear lights
Can anyone recommend led rear lights that won't throw up a can bus warning cheers
Re: Led rear lights
dont buy cheap
dectane are good, theres an ebay Shop too
Re: Led rear lights
I have dectane ones they throw a fog light code.
Re: Led rear lights
That's wot I want to avoid the dreaded codes, so I'm trying to find a plug and play set.
Re: Led rear lights
I've had 2 sets of rear LEDs and both threw up the odd error when starting the car in the dark with auto lights on but after a couple of months the errors stopped. Any time the error did appear a quick turn off and on would fix it. Or not leave the lights on auto. If you don't have auto lights then you will probably never see the error as it only came on when starting the car from cold with the lights in ie low battery level and trying to check lights at the same time.
Re: Led rear lights
Cheers mike fish I do unfortunately have auto lights but if I use them manually they should be ok is that wot u mean, tell me I have 2 switches one is for drl and thair is another by the side of it do u no wot thiss is for is it adaptive headlights?
Re: Led rear lights
i think thats your dash light dimmer.MarkV8 wrote:Cheers mike fish I do unfortunately have auto lights but if I use them manually they should be ok is that wot u mean, tell me I have 2 switches one is for drl and thair is another by the side of it do u no wot thiss is for is it adaptive headlights?
Re: Led rear lights
Hahaha it is to I'm blinder than 3 bats together cheers budStarry wrote:i think thats your dash light dimmer.MarkV8 wrote:Cheers mike fish I do unfortunately have auto lights but if I use them manually they should be ok is that wot u mean, tell me I have 2 switches one is for drl and thair is another by the side of it do u no wot thiss is for is it adaptive headlights?
Re: Led rear lights
To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
Re: Led rear lights
I'm with u my s4 used to do that wen it was dusk glad to no it's on the rs4 cheers fellaMikeFish wrote:To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
Re: Led rear lights
ah, i was guessing as I've not been out in the dark in mine yet, wheres the dash light adjuster then?MikeFish wrote:To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
- Surrey Sam
Re: Led rear lights
+ & - buttons below the rev counterStarry wrote:ah, i was guessing as I've not been out in the dark in mine yet, wheres the dash light adjuster then?MikeFish wrote:To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
Re: Led rear lights
I didn't know it could be adjusted, thought it just worked in conjunction with the lights...
Re: Led rear lights
Every days a school day... thanks SamSurrey Sam wrote:+ & - buttons below the rev counterStarry wrote:ah, i was guessing as I've not been out in the dark in mine yet, wheres the dash light adjuster then?MikeFish wrote:To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
Users browsing this forum: No registered users and 362 guests
