advice on vag com
Starry
advice on vag com
Post by Starry » Tue Aug 16, 2016 9:50 pm
Im looking to be able to plug my macbook into the car and see whats what, trouble is I've never done this before so am looking for advice on what i need, or even if you can do it on apple.
2006 RS4
Phantom black
weekenny
Re: advice on vag com
Post by weekenny » Tue Aug 16, 2016 10:55 pm
Try the Ross tech website for advice on using an apple or not. I will say one thing though buy a genuine cable or borrow one as I borrowed one from a mate at work before buying mine and it's saved me time and money on a number of occasions. Only bought one once I realised how much I'd use it.
Starry
Post by Starry » Tue Aug 16, 2016 11:38 pm
Thanks, I've emailed them....
2006 RS4
Phantom black
Post by MikeFish » Tue Aug 16, 2016 11:42 pm
This is what their website says:
There will be no "native" Mac or Linux versions. The time and effort required to "port" VCDS to these platforms would never be worthwhile. VCDS works fine on Apple Mac computers that have Intel processors (all modern Macs) when Windows is installed on them using Boot Camp. Most computers that are used to run Linux can also boot Windows. If you do not wish to install Windows, we now offer a platform-independent version of VCDS called "VCDS-Mobile".
I can confirm this works as my MacBook Pro runs windows and VCDS with no issues.
Starry
Post by Starry » Wed Aug 17, 2016 7:02 am
MikeFish wrote:This is what their website says:
Thanks for that Mike, either that or I might just get a cheap laptop and keep it in the car.
Would it work on one of those little note books?
2006 RS4
Phantom black
MB2
Post by MB2 » Wed Aug 17, 2016 10:54 am
I have a Lenovo Mixx 300 which is a mini laptop/tablet. It was 100 in John Lewis (reduced from 139 or something) it isn't the greatest computer by any means as you would imagine for that price but it works fine for VCDS and other tasks. I bought it for traveling as so small, but it is actually heavier than my full sized Thinkpad !
Starry
Post by Starry » Wed Aug 17, 2016 11:59 am
Thanks mb2. That's the sort of thing I was thinking of.
2006 RS4
Phantom black
Surrey Sam
Post by Surrey Sam » Wed Aug 17, 2016 1:03 pm
As an aside, the latest VCDS update along with the cable chip update, has really speed the fault code check process up.
Always improving their product which is great to see.
Ellis
Post by Ellis » Wed Aug 17, 2016 1:54 pm
Also note that VCDS will not work with Mac if using Windows on a virtual machine. You need to dual boot as mentioned earlier.
If only I had Googled it before I went to the trouble :bash:
iduff
Post by iduff » Wed Aug 17, 2016 7:16 pm
Ellis wrote:Also note that VCDS will not work with Mac if using Windows on a virtual machine. You need to dual boot as mentioned earlier.
Not true. I'm using a 2010 17" MacBook Pro with OS X El Capitan and Parallels, and I have a 32-BIT Windows 10 VM that runs VCDS quite happily. VCDS will run on a 64-bit VM, but ETKA and ElsaWin won't. Having my "Car" VM always with me, as long as I have my MBP with me, means I only need to add the VCDS cable to my bag to be able to troubleshoot on the side of the road.
Dual-boot will work, but is not needed.
I will echo @weekenny's sentiment, but for a different reason. Buy a genuine cable. Your purchase will support Uwe Ross and his on-going development of VCDS. @Surrey Sam is right, Uwe keeps updating it, and purchasing a genuine cable is how he affords to stay in business.
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
Ellis
Post by Ellis » Thu Aug 18, 2016 12:40 pm
iduff wrote:VCDS will run on a 64-bit VM
I stand corrected.
Ross-Tech FAQ should be updated...
Ross-Tech FAQ wrote:Systems running Windows in a virtualized environment (for example Virtual PC on a Mac) are not supported.
iduff
Post by iduff » Thu Aug 18, 2016 12:51 pm
Nah, @Ellis, you're OK. Ross-Tech is correct, they don't support it, but it does work fine. Sorry if I came across too strongly.
CPO, stock
Former Quattros
Users browsing this forum: Zyox and 363 guests
