DRL replacement
GMac7
DRL replacement
Post by GMac7 » Thu Aug 04, 2016 5:57 pm
Does anyone know where i can purchase some standard DRL lamps for my B7 RS4?
Not really wanting to go down the LED route, just looking for OEM lamps.
Cheers :bowdown:
B7 RS4 Daytona Grey
Re: DRL replacement
Post by MikeFish » Thu Aug 04, 2016 6:05 pm
Any Shop that sells car lamps?
TobyRS4
Re: DRL replacement
Post by TobyRS4 » Fri Aug 05, 2016 12:11 pm
MikeFish wrote:Any shop that sells car lamps?
Very blunt but very true :bigwave:
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
GMac7
Re: DRL replacement
Post by GMac7 » Sat Aug 06, 2016 12:47 pm
:knob:
B7 RS4 Daytona Grey
Re: DRL replacement
Post by MikeFish » Sat Aug 06, 2016 7:18 pm
GMac7 wrote::knob:
Me or you?
sckrs4
Re: DRL replacement
Post by sckrs4 » Thu Aug 11, 2016 11:25 am
Hi GMac7
Did you get the new DRL bulb ?
I too need to replace mine as I got the warning come up today and passenger side DRL is gone off (not bad since now its over 10 years !) . Checked with Audi its under a fiver for the blub.
I've seen a lot on replacement LEDs etc, not quire sure to go with OEM or LED's Any thoughts guys?
Did you do it your self ? If so, how easy was it?
S.
GMac7
Re: DRL replacement
Post by GMac7 » Fri Aug 12, 2016 6:38 am
Hello
There was a very helpful thread by Covkiller :jump_clap: , i have ordered the same lamps as below, but i am off working just now, but i'll install them when i'm home.
http://www.ebay.co.uk/itm/2-x-P21W-1156 ... 3a97f0fcee
B7 RS4 Daytona Grey
Re: DRL replacement
Post by MikeFish » Fri Aug 12, 2016 7:11 am
OEM will obviously be trouble free in terms of errors but look like <beep>.
After trying loads of LED bulbs I couldn't find any that were actually error free so in the end I gave up and bought a set of cancelling units from Trups.
Trups now has some new bulbs that he has manufactured that look the business and should be error free. If I needed new bulbs I'd probably go with these. If you dont mind the yellow buttery look then oem will do the trick.
As for changing them, its not technically difficult, but unless you have the hands of a petite lady or a 6 year old you will lose some skin on your hands and swear a lot. Passenger side is easier as the drivers side has the radiator hose in the way. You need to lift off the plastic cover on the passenger side and for the drivers side you need to remove the air filter intake.
Trups
Trader (Expired)
Re: DRL replacement
Post by Trups » Fri Aug 12, 2016 7:32 am
Here is the link to my new led ones - viewtopic.php?f=93&t=120488
Users browsing this forum: Bing [Bot] and 190 guests
