Carbon clean? Bang for buck?
Re: Carbon clean? Bang for buck?
Seems I wasn't clear enough; what I was suggesting was a regular Terraclean MIGHT prevent (or reduce) the carbon build up. You can hear the engine run smoother and smell the exhaust improvement as the neat ionised fuel under pressure is run through. Cleaning is clearly occuring and anything that lets the engine breathe better might slow the carbon build up. The carbon shifted disappears as CO2 - I wasn't suggesting for a moment you could hope for or want anything to lift off great lumps of baked on deposits.
Anyway, back to jonytec's post - has any of this helped you decide on carbon clean, remap or both?
RS6 PE DMS, Daytona, Pano., 21" 5-V-Spoke Tit.Alloys, C/Ceramics, Dynamic Pack +, Parking Pack Adv., Assist. Pack, TV (MMI only), Road Angel (essential) + Python, A. Connect & Phone Box + S/phone Interface, Head-up Display and Night Vision Assist., RS6 Proj. Puddle Lights, Clear 3M Wrap.
Mini Cooper S ("hot"Chili) 265BHP; VW Fox 59BHP; Citroen C1 68BHP!!
RS4 (B7) w. TTS S/C, C/Ceramics - sold
Audi TT Coupe won at model launch, for 3 months, from Audi UK !
- PetrolDave
Surely once the inlet manifold becomes "dry" again (when the cleaning stops) carbon buildup will restart again at the same rate as before?harrier wrote:Seems I wasn't clear enough; what I was suggesting was a regular Terraclean MIGHT prevent (or reduce) the carbon build up. You can hear the engine run smoother and smell the exhaust improvement as the neat ionised fuel under pressure is run through. Cleaning is clearly occuring and anything that lets the engine breathe better might slow the carbon build up.
Terraclean HAS been tried by RS4 owners in previous years and shown to have little immediate benefit and no long term benefit.
Save your cash for regular Italian tunes - that will achieve at least as much, if not more, and make you smile instead of cringe at the bill
would you elaborate on this "Italian tune"PetrolDave wrote:Surely once the inlet manifold becomes "dry" again (when the cleaning stops) carbon buildup will restart again at the same rate as before?harrier wrote:Seems I wasn't clear enough; what I was suggesting was a regular Terraclean MIGHT prevent (or reduce) the carbon build up. You can hear the engine run smoother and smell the exhaust improvement as the neat ionised fuel under pressure is run through. Cleaning is clearly occuring and anything that lets the engine breathe better might slow the carbon build up.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Drive it hard through the rev range.
A large dose of WOT!
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
Italian Tune = Wring it out when you can.
And when on the Autobahn, fill up with Aral 102 and wring it out until you're empty and then repeat until your deaf !
Don't forget the first stage of the Italian Tune-Up:
1) Examine rearview mirrors to confirm lack of any REO presence.
2) Punch it!
2) Punch it!
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
CPO, stock
Former Quattros
In reply to Petroldave, I am not so dismissive of Terracleaning as my RS4 B7's CO went from 0.199% pre to 0.010% thirty two days post cleaning and more relevantly to carbon cleaning, particularly in the short term, Hydrocarbons went from 54ppm pre to 14ppm post! If engine fuel combustion is more efficient, then won't there be less petrol/carbon from the re-breathing tubes to coke it up, but hey what do I know?
Terraclean/EngineCarbonClean may well clean out some stuff post combustion...the process involves pumping oxygen and hydrogen into the intake which will no doubt result in a hotter and more efficient combustion, allowing gunk to be fired out of the exhaust while the engine is being rev'd furiously.
However, our carbon build up issue is pre-combustion, in the intake manifold. Have a look through my thread and the video. We tested it on a dyno, borescoped a golf before and after the clean, and even ended up pulling the manifold off the RS4...EngineCarbonClean did not clean out the carbon.
2007 RS4 B7 Avant
FaisalJ wrote:Terraclean/EngineCarbonClean may well clean out some stuff post combustion...the process involves pumping oxygen and hydrogen into the intake which will no doubt result in a hotter and more efficient combustion, allowing gunk to be fired out of the exhaust while the engine is being rev'd furiously.
off topic but i like your new sig faisal
- PetrolDave
+1FaisalJ wrote:Terraclean/EngineCarbonClean may well clean out some stuff post combustion...the process involves pumping oxygen and hydrogen into the intake which will no doubt result in a hotter and more efficient combustion, allowing gunk to be fired out of the exhaust while the engine is being rev'd furiously.
A cleaner burn will mean less carbon is being generated in the short term but will have no effect on removing the carbon that is already the in the intake manifold.
Terraclean, and other similar schemes, are not a method of doing a carbon clean - the only way is to take the intake manifold off and use good old fashioned elbow grease.
Yeh me toors4pat wrote:FaisalJ wrote:Terraclean/EngineCarbonClean may well clean out some stuff post combustion...the process involves pumping oxygen and hydrogen into the intake which will no doubt result in a hotter and more efficient combustion, allowing gunk to be fired out of the exhaust while the engine is being rev'd furiously.
undecided on terracleans, although id make sure whoever is doing it is properly clued up, MRC noted to me on service they thought mine may have been done at some stage as the air filter was damaged which implies not done correctly, either way if it had been done their notes on the carbon build up were that it hadn't appeared to touch it.
then again we go round in a big circle to the Carbon clean skeptics that say did it clear it but it has built back up again so............
So, any decision yet on carbon clean or re-map or both?
Sorry guys I've been away for the past week and just catching up now.
I'm thinking that the first stop will be a health check and dyno run at MRC and then looking at options off the back of their recommendations. The clean will be put on hold unless it's recommend and will look more into an exhaust and remap. I'm not going to ask about exhausts though, I imagine that would ignite its own opioniated debate.
thanks for the help.
If your car is not outputting around 410bhp (assuming standard) then I'm fairly sure MRC will recommend a carbon clean to get the number up to normal. And unless it has had a recent carbon clean then it won't be making these numbers. Which brings us back to the original question; to clean or not to clean?
Users browsing this forum: No registered users and 256 guests
