Hi guys,
I've a Problem with my rs4 b7 sometimes my epc and engine light is lighting.
Mistake: P2015 intakeflapposition sensor implausible.
what should i do?
P2015 Intakeflapposition sensor implausible
Re: P2015 Intakeflapposition sensor implausible
At a guess, a flap position sensor of which there are 2 and positioned on one end of each bank, has failed OR your intake manifold is stuffed full of carbon and jammed the flaps open/closed!!!
I've got this, is it manifold off to replace the sensor?
should i only clean and replace this one sensor?
It is manifold off to replace both sensors unfortunately
Im pretty sure this is what i had & as Richie said it can be due to carbon as mine was, so after a clean & removed flaps MRC mapped it out so no need to replace if your going to have it mapped.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
pixsaudisex2
Well I did one sensor a year ago. No more faults until last week. Now the other sensor has gone. So hopefully replace that and il be back up no epc light when ever it feels like it. Bank one you can change on the car bank 2 I think I'm gona have to remove the Dam inlet but I don't wanna look at all that carbon again..
Users browsing this forum: Bing [Bot], Google [Bot] and 124 guests
