Another brake disk thread...
I have been trawling the forum and website for a few days trying to work out what front and rear brake disks I should get.
Obviously the OEM ones are easy to get hold of and are around £1300 delivered.
I spoke to MRC and Brembo have released some replacement front disks at just under £600. They may have also released some rears but waiting to hear back.
VW Phaeton disks are around £400 for the front and I'd prob get them grooved (can get it done for free).
I can't find any alternatives for the OEM rear disks, not sure if the standard Phaeton disks would go on? If so I'd get those grooved to match the fronts.
I'd appreciate any thoughts or alternative solutions.
Thanks,
Doug.
Thanks,
Doug.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
Re: Another brake disk thread...
AP Racing do a 2 piece setup for the B7 for £800 initially (2x rotor & 2x bell) and then £600 (2x rotor) when they need replacing. AP Racing Website
RH Rotor = CP8080Z14SD - £300
LH Rotor = CP8080Z15SD - £300
RH/LH Bell = CP8080Z140 - £200 for the pair
Girodisc do 380mm fronts and standard sized rear rotors, both front and rear can be bought disc, or just as rotor with bolt kit when the rotors wear, so similar to AP in that you only buy the bells once
380mm fronts, come with the spacer for the caliper bracket - http://www.girodisc.com/Girodisc-Front- ... _6337.html
Rears - http://www.girodisc.com/Girodisc-Rear-2 ... _6338.html
Price is probably completely non-competitive now that the pound has weakened as they are made in US&A
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
ecs tuning make std size discs for the rs4 $800 for the front and $550 for the rear $200 for post im thinking about getting them myself. once you have bought them it the same as the others you can buy just the rotors
Thanks for the suggestions above, I see on the ECS website that Brembo are doing front and rears at a pretty good price $610 front, $647 rears and $200 for the shipping. I assume these are exactly the same as OEM without the Audi branding.
2010 987 Cayman S.
Don't forget to add 20% VAT to stuff from the US, just incase you get pinging by customs.
Good point.
2010 987 Cayman S.
Keep an eye out for discounts at eurocarparts...
viewtopic.php?f=35&t=120805
£450/pair of front brembos is hard to beat
2007 RS4 B7 Avant
As above!
£450 is hard to beat!
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Despite my trawling I had missed that thread! Thanks for pointing it out. Just had a look and currently Euro are offering 20% off so thats £543.98, not too bad at all.
The cheapest I can find some yellow stuff pads is at EBC brakes's website and they're £177. From reading all the threads these seem to be the pad of choice? As well as having a wear sensor for slightly forgetful people such as myself....
2010 987 Cayman S.
Yellow stuff is a bit hit and miss. Been told to avoid them but had them on my other car with no problems. Maybe depends on the driving styledougle_turbo wrote:Despite my trawling I had missed that thread! Thanks for pointing it out. Just had a look and currently Euro are offering 20% off so thats £543.98, not too bad at all.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
I've been out in the car tonight and had the horrible break wobble from the front as under very hard breaking I can feel it through the pedal and although my discs don't look to worn there is slight grooving on them and there not 100% smooth , so looked on eurocar parts and using promo code summersale there £504 . May as well do it along with the pads .
I've just bought new front discs for exactly the same reasons, just trying to decide on brake pads now
Great spot, looks like they have added another 5% to their sale!Harris. wrote:I've been out in the car tonight and had the horrible break wobble from the front as under very hard breaking I can feel it through the pedal and although my discs don't look to worn there is slight grooving on them and there not 100% smooth , so looked on eurocar parts and using promo code summersale there £504 . May as well do it along with the pads .
2010 987 Cayman S.
Mine are being delivered today from that offer. Best stoke Audi could do was £636 for fronts, same for rears which I need as well. Noticed europarts do a pagid rear disc, anyone tried these?
Users browsing this forum: Google Adsense [Bot] and 101 guests
