Just got rear ended!
Nobby
Re: Just got rear ended!
Post by Nobby » Mon Jun 27, 2016 11:43 am
audi_driver79 wrote:Happy Days!
His insurers accepted liability so they will take the quote I get from my own garage and get it authorised and give me a like for like courtesy car. Hopefully my renewal wont be affected considerably..
Hope it works out for you. When someone crashed into my car they wanted to give me a courtesy car too - a like for like according to the paperwork. I didn't realise that the RS6 and a FIAT 500 were classed as like for like..... :roll:
Daytona RS6 Avant
audi_driver79
Post by audi_driver79 » Tue Jun 28, 2016 9:34 am
Enterprise did mention a Mercedes. .. Don't think it will be a C63 though.
C5 RS6 Avant Mugello Blue, Original Springs.
2001 A2 1.4tdi 75bhp. Runs on fresh air!
Post by Shoppinit » Tue Jun 28, 2016 9:39 am
The crapper the car the better. That way you'll be happier to get back in yours.
audi_driver79
Post by audi_driver79 » Tue Jun 28, 2016 6:09 pm
Don't doubt it but then it's going for a service to be ready for AITP. Just noticed a vibration which varies with speed coming from front left I think I wonder of that could be the cause of my abs light. Could it be a problem with that arm?
Ajc
Post by Ajc » Thu Jun 30, 2016 5:48 pm
Is it not just a simple case of a weight come off the front wheel and it needs rebalancing ?
Cheers Al
audi_driver79
Post by audi_driver79 » Thu Jun 30, 2016 10:49 pm
Hope it is, a nice easy solution for a change. I'll try and get it checked while its in for the paint job..
audi_driver79
Post by audi_driver79 » Mon Aug 01, 2016 1:08 pm
Just an update. I ended up getting a VW Transporter as a courtesy as I am moving house so thought it would save me renting one. I'm happy with the paint job but they left one parking sensor not repainted but they said they will do it in a couple of weeks when paint is settled. That's fine as I will probably get another one done on the front. I keep looking at the badge on the back and maybe it's my OCD but it may not be exactly right. I guess there are measurements somewhere for the exact spot if anyone can help?
Now just my annoying ABS problem to remedy buts it's going in for a service tomorrow.
Ajc
Post by Ajc » Mon Aug 01, 2016 3:05 pm
The rings look too high are they not ? .
Cheers Al
IanH755
Post by IanH755 » Mon Aug 01, 2016 4:55 pm
Here's the Rear RS6 badge - viewtopic.php?f=2&t=104391&hilit=badge+location#p605811
I'll have a look for the 4 rings spacing later.
simonpoulton
Post by simonpoulton » Mon Aug 01, 2016 5:14 pm
Just had a measure of mine - looks like the Audi rings are 20mm from the bottom of the ring to the non metal bit!
Past: R56 Mini Cooper S
audi_driver79
Post by audi_driver79 » Mon Aug 01, 2016 7:32 pm
Bloody hell I was on about the RS badge but now it's glaringly obvious it's the rings! Def too high, would it be easy to move them or ask the bodyshop to? Check out the before..
IanH755
Post by IanH755 » Mon Aug 01, 2016 8:09 pm
They're stuck on with double sided tape and the rings don't flex at all so you're more than likely to snap them if you're not very careful.
Mɐʇʇ
Post by Mɐʇʇ » Mon Aug 01, 2016 10:32 pm
Try waxed dental floss to remove it.
Post by Shoppinit » Mon Aug 01, 2016 10:38 pm
The position of those rings is a bit of a shocker.
audi_driver79
Post by audi_driver79 » Mon Aug 01, 2016 11:40 pm
Ok if I have to use dental floss what do I use to stick them back on with?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 553 guests
