For those with Audi Sports Exhaust...
Powerenhancer
Post by Powerenhancer » Fri Jun 24, 2016 10:46 am
Is your engine smooth on initial cold start-up? My old 2014 model with standard exhaust was smooth throughout. However, the 2015 model I just collected with sports exhaust shakes and vibrates for the first 10-20 seconds. It then becomes smooth when the RPMs drop to normal idle speed?
Re: For those with Audi Sports Exhaust...
Post by MikeFish » Fri Jun 24, 2016 12:05 pm
Can't say I've noticed any shakes and vibrations when starting cold other than normal ones. Mine is a 2016.
Assuming there is something wrong and you are not being paranoid, then check secondary air injection. Have you done a scan?
zebede
Post by zebede » Fri Jun 24, 2016 5:23 pm
Nope it's as smooth as a freshly waxed lady part
Zebede
911 C4s cab - summer is fun :D
Panamera Turbo - fully loaded - gone
RS6 C7 - Panther Black - dodgy steering
911 GT3 - awesome but ate tyres
RS4 b8 - Black on Black with Black windows
911 Targa 4s 991 - Black with Grey Leather
Powerenhancer
Post by Powerenhancer » Fri Jun 24, 2016 10:06 pm
Thanks, will get the vdcs on it Monday. Failing that, back to the dealer.
zebede
Post by zebede » Sat Jun 25, 2016 1:04 am
Sorry I wasn't more descriptive but I may have been blocked ;-)
Zebede
wildbore
Post by wildbore » Sat Jun 25, 2016 7:28 am
Powerenhancer wrote:Is your engine smooth on initial cold start-up? My old 2014 model with standard exhaust was smooth throughout. However, the 2015 model I just collected with sports exhaust shakes and vibrates for the first 10-20 seconds. It then becomes smooth when the RPMs drop to normal idle speed?
This sounds normal to me. On startup the exhaust flaps are open so there is quite a bark and a rumble, and idling is poor and slightly lumpy before settling down to a whisper-quiet tickover after about 10-20 seconds. Occasionally, this startup rumble sets my engine into a very rough idle that can shake the car slightly. I clear it with a small dab of throttle.
Done that on every startup since new (now on 19000 miles).
Gazsouthgate
Post by Gazsouthgate » Sun Jun 26, 2016 4:16 pm
Im very familiar with what you at describing. Bit grumbly on start up but then as soon as I put into gear the revs chill out. If left in P it calms down after 20 seconds or so as you say. Totally normal in my view.
Powerenhancer
Post by Powerenhancer » Mon Jun 27, 2016 8:46 pm
Yes, grumbly is a good description. Feels like misfires and the car wobbles a little until the revs fall to normal. My 2014 with standard exhaust was silky smooth during cold start-up as a comparison.
Full Vagcom check today and couldn't find any errors.
Gazsouthgate
Post by Gazsouthgate » Mon Jun 27, 2016 9:21 pm
Yeah, interesting - I had a misfire on my Boxster back in the day a couple of times and I thought EXACTLY the same thing first time i had a cold start up on the audi, but figured there are so many systems that any probs would be alerted to me on the dash, and since then I haven't really worried about it. I call it character! And sounds like Vagcom agree!
Post by MikeFish » Mon Jun 27, 2016 9:59 pm
As described above, mine is noisier when first started until about 20 seconds or it is put into gear. But no vibrations or wobbles, just lovely deep V8 burble.
Bit_evl
Post by Bit_evl » Tue Jun 28, 2016 10:10 am
+1 on startup it likes to grumble a bit for a minute.
Prod the accelerator clears it quicker if you need to.
Slight feeling of imbalance
Louder
slightly higher revs
Post by MikeFish » Tue Jun 28, 2016 10:35 am
I paid more attention to mine this morning and while in the cold start phase it may have been vibrating a bit more than I thought. Only slight though.
Powerenhancer
Post by Powerenhancer » Tue Jun 28, 2016 12:18 pm
Sounds like it could be normal. I feel it through the drivers seat the most.
Apologies if I have switched on anyones OCD's!
