C5 RS6 Oil Cooler Pipe - Part number/Source Required Urgent
sulli
Post by sulli » Tue Jun 21, 2016 2:56 pm
My oil cooler pipe on my C5 RS6 has corroded near the bracket that can be seen through the lower grill. It's dripping oil and if it goes completely and drops loads of oil I understand could be expensive, so need to order the part ASAP and fit it (front end off?)
Audi have got me the part number M V4B3 317 816 C for N/Stock Line at a price of £190 :assflash: (it's 24 inches of cooler pipe with a connection either end ffs.
Anyway, anyone know the best place to get this part?
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
Re: C5 RS6 Oil Cooler Pipe - Part number/Source Required Urg
Post by Shoppinit » Tue Jun 21, 2016 3:12 pm
I think Chunky79 might have a spare one. If not, he knows all about the variations since I think he bought all of them when he did.
Post by Shoppinit » Tue Jun 21, 2016 3:15 pm
Shoppinit wrote:Depends on the VIN of the car. Looks like there was a change halfway through production.
Gearbox oil (top pipes)
Left: 4B3 317 817E (G for later cars)
Right: 4B3 317 819D
Engine oil (bottom pipes)
Left: 4B3 317 815B
Right: 4B3 317 816B (C for later cars)
Left is from POV of driver.
Post by Shoppinit » Tue Jun 21, 2016 3:19 pm
http://www.online-teile.com/volkswagen- ... anguage=en
Or you could try Autovolks in Solihull.
sulli
Post by sulli » Tue Jun 21, 2016 3:21 pm
Right: 4B3 317 819D
Left: 4B3 317 815B
Thanks I think its the bottom one :nodder:
Y7TSY
Post by Y7TSY » Tue Jun 21, 2016 5:43 pm
Currently half way through this job on mine! Same pipe that runs past the front lower grill and into the passenger side lower side of the cooler, was going to just take mine off and drop it into a hydraulic hose specialist and get one made up, but don't really fancy the flexi hose in sight through the grill but will let you know if I find any other alternatives.
Are you going to split the pipe at the joint seen in the picture or is the pipe from Audi the full line up to the filter?
I just took the under tray off and both front arch liners to give them a clean and check a few things and makes getting to the bolts on the inside of the front bumper a bit easier!
Post by chunky79 » Tue Jun 21, 2016 7:55 pm
Just replied to Sulli.
I have my old hose in the garage 4b3 317 816b if someone ever needs it to get a pattern hose made up. The spare hose I have is the short one that goes on the other side of the cooler (I have it for sale on here) This one will be as corroded as the long pipe, but TPS got the wrong set up for me and wouldn't accept returns.
sulli
Post by sulli » Tue Jun 21, 2016 8:37 pm
Y7TSY wrote:Currently half way through this job on mine! Same pipe that runs past the front lower grill and into the passenger side lower side of the cooler, was going to just take mine off and drop it into a hydraulic hose specialist and get one made up, but don't really fancy the flexi hose in sight through the grill but will let you know if I find any other alternatives.
Interested in the hydraulic hose specialist thing, was thinking the same myself, saw it in wheeler dealer since, much better alternative. Know any?
I am getting mine done in a garage, have no time to do myself.
Ajc
Post by Ajc » Tue Jun 21, 2016 9:19 pm
If you can't find a hose specialist, Have a chat to some air conditioning company's. They make up bespoke pipes and use crimp fittings . I use a company called Polar Air conditioning, Based in the northwest . Not sure how far they are from you .
Cheers Al
sulli
Post by sulli » Tue Jun 21, 2016 9:22 pm
There's a few hydraulic hose specialists in COVENTRY where I am, big engineering base here, so have emailed a couple.
Top cat
Post by Top cat » Tue Jun 21, 2016 9:51 pm
Hi, i have exactly the same issue and am looking at options
, local garage have quoted £407 inc vat to fit new audi genuine pipe ( the long one ) but have said they could ask pirtec to come and have look at making one up.
I have heard horror stories about the brass nut to aluminium Union on the cooler being corroded and stripping threads on removal of the pipes meaning a new cooler is needed!!!
Any truth in this? All tips great fully received
sulli
Post by sulli » Tue Jun 21, 2016 9:55 pm
Pirtek are one of the ones I contacted, they are down the road from me.
Post by Shoppinit » Tue Jun 21, 2016 9:56 pm
Yes. It's very true. Have a look at the FAQ for a possible work around.
Also don't try to unscrew from the cooler. Cut the nut with a Dremel. Search on here.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 21, 2016 11:39 pm
Order the parts you need to make up a new flexible hose from torques UK - My DIY thread on repairing one of the other hoses will give you all the dimensions you need as starters. (I've used their kit for everything from oil cooler systems to fuel, brakes, even hydraulics for a powerboat - it's all good stuff). I recommend making it in teflon.
Or - Use a pipe cutter (definately not a hacksaw) to cut the damaged area and splice in a new flexible section with a couple of jubilee clips. Not an elegant solution, but less major surgery which I've done as a "temporary" fix before on a a couple of cars i had. Worked fine.
Post by chunky79 » Wed Jun 22, 2016 6:21 am
Cut the pipe union in 2 places a dremel and peel the union off the cooler, don't try undoing it at all. The thread may still be damaged, but there should be enough to tidy up with a thread file/ junior hacksaw blade.
I've used most of the Pirtek depots in the Midlands through work, the only one i'd really recommended for a job like this is Oldbury (ask for Aid to do the work)
Users browsing this forum: No registered users and 1146 guests
