Engine warning light
MarksRS
Post by MarksRS » Fri May 27, 2016 6:34 pm
Hi,
Looking for help. My engine warning light came on today. Car was little used over winter but stored in dehumidified garage and run for few miles every few weeks.
I'm not looking for what the reason is - as I'm sure there are a few! - but is anyone is essex area that has diagnostic machine so I can find fault code? Failing that, have to take it to stealers.
Any advice in meantime appreciated
Stairs
Re: Engine warning light
Post by Stairs » Fri May 27, 2016 7:06 pm
Im just outside of epping if thats any use...
Im going away tomorrow morning but back on Monday
The_Coat
Post by The_Coat » Fri May 27, 2016 7:49 pm
Where in Essex are you? I'm near Rayleigh area with Vagcom if you need a scan.
RS4 Avant - Misano Red
jaysrs4
Post by jaysrs4 » Fri May 27, 2016 9:29 pm
Usually a maf or lambda issue after long storage. It's happened to me on an R32 and my RS4.
audi_do_dat_den
Post by audi_do_dat_den » Sat May 28, 2016 10:17 am
The fuel might have gone a bit flat... you could use up what's left (gently) and then fill up with some decent juice. Wouldn't hurt to add a drop of injector cleaner.
Then give it a few miles.
If there was no fault before, it's likely to be the fuel or, as mentioned, a lambda sensor coming back to life.
It may well clear itself.
Users browsing this forum: No registered users and 218 guests
