Buying used...
Re: Buying used...
Leaving it in the car will stop you having to remember it. You can still use the rest of the tracker features though (assuming you are subscribed). The key fob is anti-hijack and theft protection. You still have a fully functional tracker too.
Doesn't the cobratrack tracker with keyfob allow Cobra to remotely disable the car if stolen? A worthy feature if you ask me (assuming they haven't already ripped it out). I'd also assume if they did rip it out it would stop the car from running?
Re: Buying used...
And congrats on the car by the way, glad it all came good in the end!
Re: Buying used...
I'm not bothered about disabling the car if it's stolen tbh, if a gang of little f*ckwits stole it, I wouldn't want it back anyway! Main thing was I didn't want to have to carry the fob around, have now taped it out of sight in the glove box. Job done.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Jimpoole12
Re: Buying used...
It really isn't that much hassle to remember the fob each time, it becomes habit....
Surely it's best to have it fitted and activated than not?....
Re: Buying used...
Looks better with the badgesvestax32 wrote: It's debagded though, can't decide whether or not I like it. Going to have to mull it over the next few days....
MY16 Audi RS6
Re: Buying used...
Looks epic - enjoy!vestax32 wrote:So, after a bad start with the Belfast C7, I flew to Glasgow and picked this up today. I am very pleased with it, MUCH better than the first attempt, DRC is night and day better than the air. Had a 400 mile drive back, so gave the car a proper test, and can't fault it. The service from Carrera Specialist Cars was extremely professional and smooth. Hopefully I can start to enjoy C7 ownership now!
Re: Buying used...
Can anyone tell me correct tyre pressures, Sticker on the door has been damaged and can't read it....
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Re: Buying used...
Not more damage !
Only joking- your car looks great and you must be rightly thrilled
Re: Buying used...
Gave it a thorough going over today, really happy with it, looks the dogs!!MSF21 wrote:Not more damage !
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Re: Buying used...
Is it not in the user manual? From memory, according to the MMI from fronts are set at 32psi and the rears about 27. I could be mistaken though. I can check the door later.
Re: Buying used...
Manual says to check the sticker. I'm pretty sure it's 41psi front and 39psi rear, but this is a long way off your suggestion Mike, are you sure about 32 & 27?!MikeFish wrote:Is it not in the user manual? From memory, according to the MMI from fronts are set at 32psi and the rears about 27. I could be mistaken though. I can check the door later.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Re: Buying used...
no not sure, actually, isn't the display in bar? maybe it was 2.7 bar not 27 psi. I just recall the digits. 2.7 bar is about 39psi so spot on with your rear figure.
Re: Buying used...
You can switch the display between bar and psi. After a bit of research, I can confirm its 41 & 39. Have ordered a new sticker fro the stealers, £8 for a sticker, thriving b*stards!MikeFish wrote:no not sure, actually, isn't the display in bar? maybe it was 2.7 bar not 27 psi. I just recall the digits. 2.7 bar is about 39psi so spot on with your rear figure.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Re: Buying used...
....says the man who has just paid £60,000 for a two year old estate car.
Re: Buying used...
Touché!Ian_C wrote:....says the man who has just paid £60,000 for a two year old estate car.![]()
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Users browsing this forum: Google Adsense [Bot] and 90 guests
