ABS and ESP lights on
pete62
Post by pete62 » Tue May 17, 2016 3:07 pm
So a bit of help please ,
The last couple of times I have taken the car out I have had an intermittent problem. For no apparent reason the ABS and ESP light come on and stay on. If I stop and turn the ignition off and back on it goes away . It's happened a couple of times.
I used a simple code reader ( not Vagcom) and it came up code 00287 which I believe is 'ABS wheel speed signal #3 (right rear) range performance G44'.
So what am I looking for ? Is there a specific component to check and if so where ( other than somewhere near the right rear wheel) is it.
All help gratefully received
Re: ABS and ESP lights on
Post by Shoppinit » Tue May 17, 2016 4:07 pm
Lots of threads recently about this. Could be wheel sensor, but it's more likely to be a failing ABS unit. If you change the sensor and the fault remains, then it could be that.
Post by Shoppinit » Tue May 17, 2016 4:10 pm
pete62
Post by pete62 » Tue May 17, 2016 6:32 pm
Thanks Shop, will wait and see what the result is on that thread. Small but important point which is the right the drivers or passenger side?
Post by Shoppinit » Tue May 17, 2016 9:37 pm
The right of the car as if sat in the drivers seat.
pete62
Post by pete62 » Wed May 18, 2016 10:35 am
Thanks Shoppinit
So I assume this is it . Removed the bolt but doesn't seem to want to come off. Is this a brute force to encourage it or am I missing something?
Post by Shoppinit » Wed May 18, 2016 10:54 am
It appears to be a biatch to persuade out judging by the Passat forums, but I haven't done it myself.
pete62
Post by pete62 » Wed May 18, 2016 10:56 am
Thanks will give it a little tap then!
pete62
Post by pete62 » Thu May 19, 2016 1:05 pm
So no success getting the sensor out. Online vids suggest that removal by trashing the sensor is favourite . I didn't want to do this as it has only happened twice.
Circumstances are that I had to pretty much emergency stop ( on the way to its MOT)and the lights came on at that time. Switched off and they went away then no problem for a few drives until I was in stationary traffic for a while holding the car on the foot brake and whilst stationary they came on again. Once I was moving again and could stop I did and again switched off and cured.
After trying yesterday to remove the sensor involving a lot of tapping etc a lot of crud came out of the disc so I'm kinda hoping ( yeah I know 'dreamer') that perhaps it was contaminated ?
Went out today lots of different driving lots of bumpy roads lots of braking, no sign of any fault......................? :?: :?:
Post by Shoppinit » Thu May 19, 2016 1:10 pm
Fingers crossed then. Let's see if the fault comes back.
Pretty sure people on here have swapped their sensors, so might be worth pinging them on those other threads.
audi_driver79
Post by audi_driver79 » Fri May 20, 2016 12:47 am
My fault is still persisting and my speed sensors luckily came out easily. I really do think it's the ABS unit now on mine.
C5 RS6 Avant Mugello Blue, Original Springs.
2001 A2 1.4tdi 75bhp. Runs on fresh air!
Post by Shoppinit » Fri May 20, 2016 9:18 am
Seems to be a common fault as they get to this age. As if we needed another £1000+ programmed failure. :roll:
monoi
Post by monoi » Fri May 20, 2016 10:34 pm
There indeed seem to be a spate of those things going around at the moment.
The way AMD found the fault after checking the wheel speed sensors was to follow the loom and they noticed that the fault would come on when moving the loom close to the abs unit. Old fashioned technique. Unfortunately, the fault on mine was not a short in the loom.
A new ABS unit with the labour is £2000+...
audi_driver79
Post by audi_driver79 » Sat May 21, 2016 12:05 am
Or send the electric module to ecutesting.com for about £200 and they will fix it and cover it with a lifetime warranty.
http://www.ecutesting.com/audi_abs_pump ... ator_.html
http://www.ecutesting.com/catalogue/pro ... 50036.html
Post by Shoppinit » Sat May 21, 2016 9:19 am
Are these people reputable? Unlike some other ABS repair people that have been mentioned?
Users browsing this forum: Google Adsense [Bot] and 194 guests
