car back after gearbox rebuild
G pat
Post by G pat » Sun May 15, 2016 4:30 pm
Right, so i picked the car up on yesterday, gearbox all good so far, there is a problem though.
I noticed today when turning left or right, say pulling out of a t junction, the front wheels seem to scrub or slightly shudder until i start to straiten up.
Does anyone have an idea why, it was ok before, could they have not resembled something properly.
Thanks.
Re: car back after gearbox rebuild
Post by Shoppinit » Sun May 15, 2016 6:04 pm
On full lock?
G pat
Post by G pat » Sun May 15, 2016 6:23 pm
No just a normal kind of scenario pulling out of T junction, so not quite full lock, although I'm sure it would do the same at full lock
atledreier
Post by atledreier » Sun May 15, 2016 7:42 pm
I have that as well, I figured it was the center diff binding up?
Sent fra min SM-N910F via Tapatalk
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
Human Joist
Post by Human Joist » Sun May 15, 2016 7:44 pm
You sure it's not coming from the back. I get that as the rear dif sorts the rear end out and the tyres fight. Normal for a Quattro mate. If that's what your on about I had that on my S2, B5 RS4 and now C5 RS6.
atledreier
Post by atledreier » Sun May 15, 2016 9:21 pm
I thought the front and rear diffs were open on the c5? So only the center diff would bind.
2012 Toyota GT86
G pat
Post by G pat » Sun May 15, 2016 10:02 pm
thing is it didn't do it before. I'm wondering if it could be that the drive shaft hub bolts were undone and tightened back up with the car on the ground, which audi say you should not do. The engine removal breakdown states that the drive shaft hub bolts should be removed with the car in the air and a second person holding their foot on the brake to stop the hub turning.....I might undo and do back up then see what happens.....
Post by chunky79 » Mon May 16, 2016 7:00 am
G pat wrote:thing is it didn't do it before. I'm wondering if it could be that the drive shaft hub bolts were undone and tightened back up with the car on the ground, which audi say you should not do. The engine removal breakdown states that the drive shaft hub bolts should be removed with the car in the air and a second person holding their foot on the brake to stop the hub turning.....I might undo and do back up then see what happens.....
Or just ask the guy's who did the work how they tightened them?
Does the noise come from both sides or just the one?
simonpoulton
Post by simonpoulton » Mon May 16, 2016 7:10 am
Any idea which method they used to get the engine out? You can either separate from subframe and drive shafts and lift it out, or actually drop it out with the subframe and lift the car up.
I haven't personally done the latter, but as it comes out with all the suspension still attached to the subframe, I wonder if the suspension its self has been messed around with?
Past: R56 Mini Cooper S
Post by Shoppinit » Mon May 16, 2016 8:41 am
Yeah, could be that it needs a 4 wheel geo. The scrubbing might be excessive toe.
Users browsing this forum: Google Adsense [Bot] and 291 guests
