So I replaced the battery again as it was reading low voltage and wouldn't keep a full charge.
Had another issue of not starting at a petrol station again this weekend. Did a scan and got the following, any ideas?
01 Engine Control Module 1
System description: 4.2L V8/4V FSI ª
Software version: 0090
Hardware number: 8E1910560
Long coding: 01040003180F0160
Trouble codes:
P3088 - Starter relay Electrical error in circuit Upper limit exceeded
Intermittent
P1923 - Check DTC memory of Engine Control Module (ECM) 2 Implausible signal
static
Battery issue
- PetrolDave
Re: Battery issue
DID you scan the other engine ECU at address 11 as well? That is referred to by the P1923 code.
Re: Battery issue
Yeah, this is what came up.
Engine Control Module 2
Trouble codes:
P1411 - Bank 2, secondary air system Flow too Low Lower limit not reached
Intermittent
Measurements: -2199 U/min 16 % 58 km/h 36 °C 28 °C 1000 mbar 12.319 V 22.0 °v.OT
Frequency counter: 3
Mileage: 131525 km
Driving cycle: 255
Priority: 0
Trouble codes:
Intermittent
Mileage: 131525 km
Driving cycle: 255
Priority: 0
- PetrolDave
Re: Battery issue
Both are intermittent, have you tried clearing them and seeing if they return?
The P3088 suggests if they return that it could be the (very common) relays underneath the ECU problem.
Re: Battery issue
Yeah have cleared them previously and the above one does occasionally return, the other starter one crops up more often.
Users browsing this forum: No registered users and 111 guests
