Odd starter issue
irishmike
Odd starter issue
Post by irishmike » Fri May 13, 2016 3:04 pm
Following on from my previous Battery issue I am still having issues starting the car on occasion
I've changed the battery twice now, first time was actually a dodgy battery contributing to the issue.
However now I know the battery is fine and I'm still having issues.
Symptoms are as follows:
Car starts perfect when cold - every time
When properly warm, driving for 30mins plus, if I stop it may not start. Does not turn over, just a slight click when the button is pressed
Leave it for 10 mins and starts fine
Scan shows the below:
01 Engine Control Module 1
System description: 4.2L V8/4V FSI ª
Software version: 0090
Hardware number: 8E1910560
Long coding: 01040003180F0160
Trouble codes:
P3088 - Starter relay Electrical error in circuit Upper limit exceeded
Intermittent
Any ideas?
CaptainLeadFoot
Re: Odd starter issue
Post by CaptainLeadFoot » Fri May 13, 2016 4:11 pm
your starter relay is stuffed from the code, literally.
andyg72
Post by andyg72 » Fri May 13, 2016 4:16 pm
I replaced both starter relays there about £30 each
And clutch switch £15
Then starter motor £385 :bash:
irishmike
Post by irishmike » Fri May 13, 2016 4:31 pm
Was it a similar issue?
irishmike
Post by irishmike » Fri May 13, 2016 4:32 pm
CaptainLeadFoot wrote:your starter relay is stuffed from the code, literally.
Would that not act up when cold too?
CaptainLeadFoot
Post by CaptainLeadFoot » Fri May 13, 2016 6:36 pm
This could be the relay is not discharing properly when you have warm start, which never is an issue with cold start because the charge would have been depleted
andyg72
Post by andyg72 » Sat May 14, 2016 5:45 am
irishmike wrote:Was it a similar issue?
Yes a very similar issue mike
I can remember the exact vagcom code but was pointing to the relay that's why they were replaced ultimately it was the starter motor .
r5ccu
Post by r5ccu » Sat May 14, 2016 10:51 am
Same issue I had both relays changed then starter and all was fine
Sprint blue,kw clubsports,milltek non resonated,k&n,dectane rears,led drl,20x9 rohana rc10 et25 ebc yellowstuff pads f+r revo tune
irishmike
Post by irishmike » Sat May 14, 2016 12:28 pm
Cheers guys
Audi got back to me on the prices.
325 for the starter and 7 hours to fit it!
Seems excessive...
Post by MikeFish » Sat May 14, 2016 12:34 pm
I think I said this in the other thrread, my old fiat coupe was exactly the same. The starter solenoid would jam when hot so it clicks but as the solenoid didn't fully extend it didn't turn the engine. Wait until it cools then its all fine. Changed starter motor; all good.
Post by MikeFish » Sat May 14, 2016 12:35 pm
Starter from ECP was about £142 I think. Then labour to fit.
irishmike
Post by irishmike » Sat May 14, 2016 1:02 pm
How long did it take do you remember?
Post by MikeFish » Sat May 14, 2016 6:53 pm
It's going in to be done next week. It's having a load of other work done at the same time too like the engine mount that sits under the starter motor so probably won't know the exact time.
irishmike
Post by irishmike » Sat May 14, 2016 8:26 pm
Ah ok, cheers.
andyg72
Post by andyg72 » Sat May 14, 2016 8:28 pm
I had my starter motor fitted at midland Vw genuine Audi starter and took 3 hours to fit
Users browsing this forum: Google [Bot] and 82 guests
