No power, running rich?
RS4_Ollie
Re: No power, running rich?
Post by RS4_Ollie » Mon May 02, 2016 7:03 pm
Do a full scan
JmRS4
Post by JmRS4 » Mon May 02, 2016 7:23 pm
That any good?
Log-Log.txt
(3.92 KiB) Downloaded 43 times
Log-WUAZZZ8EX6N901389.txt
(209 Bytes) Downloaded 46 times
RS4_Ollie
Post by RS4_Ollie » Mon May 02, 2016 7:42 pm
Thats only engine bank 2.
To do a full scan, from main screen, select auto scan - select chassis - start
Did you record the codes before you cleared last time?
JmRS4
Post by JmRS4 » Mon May 02, 2016 8:50 pm
Will do that now mate. No I didn't record them last time, wasn't really thinking.
JmRS4
Post by JmRS4 » Mon May 02, 2016 9:07 pm
Didn't realise there was as many other faults with things. Then again it is on vcar! That's a full scan like you said.
Log-WUAZZZ8EX6N901389-78430km-48734mi.txt
(12.28 KiB) Downloaded 43 times
RS4_Ollie
Post by RS4_Ollie » Mon May 02, 2016 9:51 pm
Nothing related to engine issues there, even your misfires are gone now so you must have done a clear since then.
It's always best to copy codes before clearing as then you can reference them afterwards.
Have you done a readiness test for the lambda system in basic settings
Grandadg90
Post by Grandadg90 » Mon May 02, 2016 11:43 pm
Looking at Ebay ad, your main cats sensor location has been changed to now being post main cat. This should stop any errors occuring, as long as you have wired it accordingly. So pre cars lambda still in the same place, pre main cat lambda now located post main cat.
By doing this the lambdas should have an air flow difference, which should stop EML coming on.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
JmRS4
Post by JmRS4 » Tue May 03, 2016 6:33 am
RS4_Ollie wrote:Nothing related to engine issues there, even your misfires are gone now so you must have done a clear since then.
I haven't done a readiness test. When I go into basic settings and click the drop down menu which one do I want to select?Image
RS4_Ollie
Post by RS4_Ollie » Tue May 03, 2016 7:40 am
Work your way through the Lambda related ones. You will also have to do bank 2
JmRS4
Post by JmRS4 » Tue May 03, 2016 8:10 pm
Gone through all of them and the only thing that looks different is the voltage for sensor 2 in bank 1. Bank 2 reads 0.950v and bank 1 reads 0.02v. Is that likely to be the cause? Cars getting new sensors fitted on Thursday so hopefully that will be it.
RS4_Ollie
Post by RS4_Ollie » Tue May 03, 2016 8:13 pm
Did you run the tests by pushing the brake and throttle together?
JmRS4
Post by JmRS4 » Tue May 03, 2016 9:47 pm
No didn't do that, not sure how to use it all to be honest mate. How do I do that? Sorry to sound stupid.
RS4_Ollie
Post by RS4_Ollie » Tue May 03, 2016 10:24 pm
Go to the particular test you want to do in basic settings, click the button at the top to turn on basic settings, press the brake and keep depressed then press the accelerator and keep down. The revs will rise and hold, test on should be displayed, keep pressing peddles until system ok (if system is ok)
JmRS4
Post by JmRS4 » Thu May 05, 2016 8:10 pm
Fitted new rear sensors today and it's running lovely just now. Hopefully that's it fixed, no fault codes as of yet. Thanks for your help.
JmRS4
Post by JmRS4 » Sun May 08, 2016 9:46 pm
Engine management light returned today. got the following codes. Anyone?
Log-Log.txt
(4.46 KiB) Downloaded 44 times
Users browsing this forum: No registered users and 207 guests
