Ext Temp sensor ?
Ext Temp sensor ?
Hello mates,
Ext Temp seems strange...
Does anyone konw where is located the ext. temps sensor ? Is it easy to change ?
Audi RS6 C6 Exclusive black-brown
Nappa leather and Ceramic
Re: Ext Temp sensor ?
How does it seem strange? the only EGT sensor i know of is located inside the pre-cat and not very easy access, in fact id assume it would be downpipe removal in order to change it which would require lowering of the subframe.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
I'd always assumed that it was over reading once the engine was warm due to the sheer heat the engine puts out. The only way to get an accurate reading would be to put the sensor on a ten foot pole in front of the car
I've seen this in other cars I've had but never as bad as the C6.
Egt sensor
Or
External (outside ambient) temp sensor?!
Think a bit of confusion going on here!?
Or
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Rs4 b5 507bhp
The External Temp sensor (how hot is the weather) is just in front of the main Radiator and slightly to the left - http://www.partsbase.org/audi/audi-rs6- ... re-sensor/
My bad read it wrong!!
I talked about exterior temp air sensor.
Thanks for sharing this part!
Is it easy to change? Do we need to remove front spoiler ?
Yes the front bumper needs to be taken off.
Thanks a lot for this help !
Has anyone had any success in improving the accuracy on a C6...?
Mine over reads by +4-5 degrees C.
Adam
RS6 Wagon - C6
RS6 Wagon - C6
New sensor fixes it... had one myself, however it is a bumper removal job to clip the new one in as any normal sized hand will just NOT fit up enough to get it in and connected.AL0500 wrote:Has anyone had any success in improving the accuracy on a C6...?
Users browsing this forum: Google [Bot] and 81 guests
