removing front disks
4.2 V8 32v FSI - 444 bhp
Brooner
Post by Brooner » Tue Apr 19, 2016 7:38 pm
Gent
stupid question but do you have to remove the pads to remove the calipers prior to taking off the disks the resion is the fronts have a lip on them and Audi put new pads on during my mot & service
i know the front pads a easy to remove so i probably will take them out prior to removing the caliper then disk off and grind off the lip
i would be looking to do the same to the rears but as they have a electronic brake is this as straight forward as remove the pads then the caliper or do i need to use the Vag Com to release the brake prior to removing them??
Revolution
Trader (Expired)
Re: removing front disks
Post by Revolution » Thu Apr 21, 2016 10:49 am
Hi
You will need VCDS (or similar tool such as snap on Solus) to put the rear calipers into what is basically a service position
where it backs the handbrake right off before you commence work.
From there it is as a normal brake replacement job, once all new bits are fitted you will need to re-activate the electronic
handbrake using the same tool.
Generally very easy to do.
Little Glen
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
Surrey Sam
Post by Surrey Sam » Thu Apr 21, 2016 11:48 am
Little Glen,
I assume that you will also need a calliper rewind tool for the rears?
Sam
Revolution
Trader (Expired)
Post by Revolution » Thu Apr 21, 2016 12:04 pm
Surrey Sam wrote:Little Glen,
Sam
Hi
Yes you will, nothing out of the ordinary though. Just your average rewind tool will be sufficient.
Glen
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Brooner
Post by Brooner » Thu Apr 21, 2016 12:52 pm
cheers Glenn all i have found on the net says the same but have seen a few vids of chancers removing the motor from the rear caliper to push in the piston
i have the Vag Com and it seems to be straight forward but the do seem to want to hook up to a battery charger to do the rears
they say the EHB is sensitive to voltage fluctuations ???
would i definitely need a charger attached???
Revolution
Trader (Expired)
Post by Revolution » Thu Apr 21, 2016 1:07 pm
Brooner wrote:cheers Glenn all i have found on the net says the same but have seen a few vids of chancers removing the motor from the rear caliper to push in the piston
i have the vag com and it seems to be straight forward but the do seem to want to hook up to a battery charger to do the rears
Realistically yes, but if you don't have a voltage stabiliser/charger then you can still do it. Switch off ALL ancillaries to reduce the load on the battery.
We have done this in pit lanes around Europe without battery chargers so we can change pads at track days.
Glen
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Brooner
Post by Brooner » Thu Apr 21, 2016 1:09 pm
Again thanks Glenn
Users browsing this forum: JamesBaby and 86 guests
