Gap between outside of brake caliper and wheel spokes
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
dazzer
Post by dazzer » Mon Jul 04, 2005 10:01 pm
Thanks Pete,
Bought my car with 18" reps on so assume I have spacers. I have has a knocking from the front right after 60mph. Sounds like I should check to see what spacer types I have as a Uni spacer could be the cause yes?
CliveH
Post by CliveH » Mon Jul 04, 2005 10:03 pm
Yes, the universal spacer is literally littered with slots and holes so that they cater for differing stud patterns and PCD diameters.
As Pete says, the hubcentric spacer fits neatly onto the hub, whereas the universal jobbie flaps all over the place.
Clive
dazzer
Post by dazzer » Mon Jul 04, 2005 10:03 pm
Thanks Pete,
dazzer
Post by dazzer » Mon Jul 04, 2005 10:04 pm
Thanks Pete,
CliveH
Post by CliveH » Mon Jul 04, 2005 10:06 pm
Dazzer,
I never thought of that when you mentioned the knocking.
You should certainly have spacers to accommodate those RS4 18" reps - whip a wheel off and check.
I have some pics of universal and hubcentric if you want to compare, but it should be apparent from the above as soon as you get the wheel off.
Clive
S4Pete
Post by S4Pete » Mon Jul 04, 2005 10:06 pm
I would definitely have a check. Unfortunately most places that sell alloys are clueless and will sell universal spacers as they only cost a couple of quid and are hassle-free to sell. But they're not clever, particularly on a performance car.
Even easier, give me your 18s and a grand and fit my Lambo rims that don't need spacers ;)
dazzer
Post by dazzer » Mon Jul 04, 2005 10:13 pm
LoL - Throw in the Lambo and you have a deal :P
dazzer
Post by dazzer » Mon Jul 04, 2005 10:14 pm
S4Pete
Post by S4Pete » Mon Jul 04, 2005 10:17 pm
You think if I had a Lambo I'd be talking to scummy S4 drivers ;)
springfield
Post by springfield » Mon Jul 04, 2005 11:19 pm
In a word,keep clear of spacers ,my wheel supplier offered them FOC, i declined,I fitted them spacers to my 944Turbo S but they were specifcaly designed to fit the car (fleisenger motorsport items)
They will probably put even more load and wear on the wheel bearings.
Jim S4 Avant. :nogarors4: (got a yellow one but likes Negaro!!)
UKS4APR1
Post by UKS4APR1 » Tue Jul 05, 2005 12:39 am
Anybody running Stoptechs on Std 17" wheels will tell you that they have no problems with a 2mm or less clearance between the spokes and the caliper.
However these are a FIXED caliper as opposed to the std. sliding caliper which can move.
I run RS4 rears on my S4 with 17" Std. wheels, they are a sliding caliper and run OK with 2mm clearance betwen the outer surface and rim.
UKS4APR1
Post by UKS4APR1 » Tue Jul 05, 2005 12:54 am
kwottro...Please remember with std. sliding calipers that when you fit new brake pads then the caliper will stick out more towards the spokes of the rim!!
You would not be the first to fit new brake pads and then lock-up the wheels when refitting them!!
springfield
Post by springfield » Tue Jul 05, 2005 9:24 am
Must remember that one when fitting new pads !
Imola Avant,Carbon,Bose,MRC Re Map,Hyperboost DV.s.
BMW E30 318iS.
kwottro
Post by kwottro » Tue Jul 05, 2005 12:43 pm
Hmm, I'll keep that in mind.
All opinions/suggestions/warnings taken onboard. Thanks all...
Users browsing this forum: No registered users and 98 guests
