Tips for removing A-pillar trim?
shadyraven
Post by shadyraven » Sun Apr 03, 2016 10:15 pm
Hi, does anyone have any tips for removing the A-Pillar trim? Curious if it has to be lifted/prided off in a certain way?
shadyraven
Re: Tips for removing A-pillar trim?
Post by shadyraven » Sun Apr 10, 2016 7:00 am
Boy oh boy, a whole week passes and not a single reply! :thumbsdown:
Ajc
Post by Ajc » Sun Apr 10, 2016 7:33 am
I'll be removing mine in the next day or so . I'll post back and let ya know what I break and how to avoid it .
Cheers Al
Cheers Al
Post by chunky79 » Sun Apr 10, 2016 7:42 am
Pretty sure there are videos on the interwebby guiding you.
How come nobody searches for things these days?
Ajc
Post by Ajc » Sun Apr 10, 2016 8:54 am
Where's the fun in that .? :wink:
Cheers Al
mavada
Post by mavada » Sun Apr 10, 2016 11:37 am
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
shadyraven
Post by shadyraven » Sun Apr 10, 2016 1:59 pm
I wasn't feeling too good with that tutorial when I read it over a week ago. Pictures don't match the RS6 interior, fixtures are off and the pull tab access for the wire does not appear when the handle is removed.
shadyraven
Post by shadyraven » Sun Apr 10, 2016 2:00 pm
Ajc wrote:I'll be removing mine in the next day or so . I'll post back and let ya know what I break and how to avoid it .
Cheers Al
Thanks. Good luck.
Ajc
Post by Ajc » Sun Apr 10, 2016 4:04 pm
Right just removed all of my pillar trims .
A pillar removal , pop out the air bag warning rectangle. Behind that is a 20 torx . Pull the grab handle down to reveal the two caps . Pop thesee out , they are hinged and will swing up towards the headlining . Under there is two 25 torx . Remove there along with the handle . Gently pull the pillar trim working from the back towards the windscreen. There is several metal clips that will pop off. Once down almost to screen slide the trim up as it's located into the dash . Don't worry if any of the metal clips are left behind in the pillar . Use a pair of pliers and pop them out and relocate them on the trim . Took me about 5 mins per side . Just be mindful of the curtain airbags that runs under this trim from almost the entire length of of the car . So don't go jabbing screwdrivers up behind the trims .
Cheers Al
Cheers Al
shadyraven
Post by shadyraven » Sun Apr 10, 2016 5:11 pm
Good summary - sounds more straightforward than the how-to samples featuring the A6 C5 interior featuring the wire pull tab. Thanks for confirming the A pillar for RS6 C5 is not the same. To future readers, ignore the suggested link shown above.
Ajc
Post by Ajc » Sun Apr 10, 2016 5:35 pm
Yeah there very straight forward. I'll be stripping the rest of the body for a repaint so if anyone wants any information of stripping other body parts, doors , bumpers ect let me know and I'll see if I can put together big Ted's guide .
Cheers Al
Cheers Al
Users browsing this forum: Google [Bot] and 172 guests
