Replacement clutch parts?
Dannorton
Post by Dannorton » Wed Apr 06, 2016 6:59 pm
Hi all, I'm currently getting all the bits together ready to get the clutch replaced,
I have so far,
Clutch, pressure plate, release bearing
Dmf from rock auto
master cylinder
Slave cylinder
Uprated feed pipe from rob
But I've heard you also need guides and seals etc..
So could someone please let me know what all the other bits and bobs I need to replace.
My clutch pedal is sticking so not sure if I need anything else for that?
Thanks!
koolade9
Re: Replacement clutch parts?
Post by koolade9 » Wed Apr 06, 2016 8:41 pm
Couple things:
-Is there a specific reason you're replacing the master cylinder?
-"Uprated feed pipe from rob"? I haven't been on 246 in a long time, what exactly does this entail? The fluid feed hose from the reservoir to the master cylinder was typically replaced as a part of a TSB. Was this not a thing on the east side of the pond?
-FYI: USP sells a metal slave cylinder (vs. OE plastic) that includes an SS clutch line as well
R1RS4
Post by R1RS4 » Wed Apr 06, 2016 9:08 pm
You will new new bolts for the DMF, new bolts for the pressure plate
New release bearing arm, it's been update change of angle
New release bearing spigot o ring
Also, if your front down pipes have not been off for a while then the studs and nuts will need replacing
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
Dannorton
Post by Dannorton » Thu Apr 07, 2016 10:12 am
Just replacing the master whilst I'm having all the work done as the cars at 80000.
Yes Robnic on here is making an uprated braided pipe from the master to the slave.
Thanks matey, I'll price it all up at Tps now!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 132 guests
