Lowering help - front only!
coffey555
Re: Lowering help - front only!
Post by coffey555 » Wed Mar 23, 2016 12:14 am
Great news, looks like your car had the wrong rear springs like my mates then.
Misano Red RS4 B7 Avant
RichieRS
Post by RichieRS » Wed Mar 23, 2016 8:28 am
Deffo the wrong springs. Where the hell the previous owner got them from I will never know!!.
Already sits about 1/2-3/4" lower than previous and if it settles another 1/4"-1/2" lower still I will be over the moon lol.
For anyone wanting to change the rears in the future then you need to remove the bottom strut bolt as well as the Camber adjustment bolt from the arm. Drop the subframe on the 4x18mm bolts whilst supporting it with jack, taking the 2 bolts on the side you are changing completely out whilst the other 2 remained in place but loose. Then drop it down on the jack until you could remove the spring (compressors on spring at this point). Fit new spring and re-insert the 2 x subframe bolts and loosely. Reassemble the arm and strut and repeat on the other side. Once finished raise the jack to lift the subframe and retighten all the bolts.
Covkiller
Post by Covkiller » Sun Mar 27, 2016 2:09 pm
Rule No1 please
And good work getting it sorted.
:thumbs:
RS4_Ollie
Post by RS4_Ollie » Wed Mar 30, 2016 5:59 pm
Changed my H&R rears yesterday back to the originals as the h&r are a little too low on the rear. Not sure if the originals are a little too high now :bash:
Thinking of putting the H&Rs in with a taller rubber spacer/seat to bring them up slightly.
Didn't find I needed the spring compressor at all or needed to remove anything else just removed lower bolt from shock and lowered the sub frame.
coffey555
Post by coffey555 » Wed Mar 30, 2016 6:09 pm
Have you got the rear H&R saloon springs fitted to the heavier Avant?
RS4_Ollie
Post by RS4_Ollie » Wed Mar 30, 2016 6:14 pm
Mines a saloon.
Springs are at work so cant check the part number until tomorrow.
RichieRS
Post by RichieRS » Wed Mar 30, 2016 8:18 pm
This is how she sits now. Back and front about level which is perfect. Got 10mm spacers front and 12mm rear and so far heard one scrape as I was going over a pretty big ramp!!!.
Thinkni might have needlessly undone the arm with the camber adjustment but I made sure to mark up where it was!!!
RS4_Ollie
Post by RS4_Ollie » Wed Mar 30, 2016 8:41 pm
My rear with the H&R was about the same as yours but the front is higher by about 20mm.
Maybe the last owner changed the front perches?
RichieRS
Post by RichieRS » Wed Mar 30, 2016 9:22 pm
RS4_Ollie wrote:My rear with the H&R was about the same as yours but the front is higher by about 20mm.
I have a felling they did mate as he gave me the old springs in a bag which had 2 perches in as well. Never told me why or that it had been done but I have seen people say the front sits higher without perches so I can only presume they are the B5 ones under there.
Covkiller
Post by Covkiller » Wed Mar 30, 2016 10:18 pm
Now doesn't that look better
May the lowered be with you my son & welcome to the Low Familia
:nogarors4: :thumbs:
RichieRS
Post by RichieRS » Thu Mar 31, 2016 7:16 am
Covkiller wrote:Now doesn't that look better
Why thank you :thumb:
Rw@@dy
Post by Rw@@dy » Thu Mar 31, 2016 7:30 am
RichieRS wrote:This is how she sits now. Back and front about level which is perfect. Got 10mm spacers front and 12mm rear and so far heard one scrape as I was going over a pretty big ramp!!!.
Sits perfect now mate!
RichieRS
Post by RichieRS » Thu Mar 31, 2016 10:00 am
sure does buddy.
You booked yours in to be fitted yet?. Perhaps look at adding the B5 perches while your in there?!!
Rw@@dy
Post by Rw@@dy » Thu Mar 31, 2016 6:01 pm
Not yet, not sure what to do, they need the car for 6.5 hrs in total!
Users browsing this forum: allroadadi, Google Adsense [Bot] and 139 guests
