c7 discs fit?
marknjayne
- 1st Gear
c7 discs fit?
Hi ,do the C7 discs fit the C6?
Re: c7 discs fit?
Short answer - No, they are not a direct fit but you could mod them to fit.
Info taken from another I put this in -
Fronts - The Hat Height is different
C6 - 59.5mm
C7 - 53.5mm
So you'd have to fit 6mm spacers to the calipers to fit the C7 discs.
Rears - I've not got any info for C7 rear Disc height but C6 is 42.5mm ***however*** the C7 discs are 22mm thick vs 28mm for the C6.
C6 - 59.5mm
C7 - 53.5mm
marknjayne
- 1st Gear
Re: c7 discs fit?
Cheers Ian,im not adding spacers so i will just have to get the C6 discs,just love the look of the C7 discs and they are cheaper,OEM Audi best?IanH755 wrote:Short answer - No, they are not a direct fit but you could mod them to fit.
C6 - 59.5mm
C7 - 53.5mm
Re: c7 discs fit?
No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly
One advantage of the AP setup is that, once you've bought them, when it come time to replace the rotors it's only £600 for a set so even cheaper than OEM.
marknjayne
- 1st Gear
Re: c7 discs fit?
excellent AP it is then ,where did you buy yours fromIanH755 wrote:No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly
Re: c7 discs fit?
Here's who I used and they arrived the next day! -
They can also supply Ferodo DS2500 pads (no wear sensor) pt no FRP3133H for £240
Hi Ian
The discs are £294.80 each and the bells are £99.70 each both prices include VAT.
Kind regards
Ewen MacRae
Clark Motorsport Ltd
Aquherton Business Unit
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860999 (Office)
01330 860111 (Fax)
ewen@clarkmotorsport.co.uk
http://www.clarkmotorsport.co.uk
You need these part numbers -
2x CP8080Z240 - Bells
1x CP8080Z24CG12 - Right Disc
1x CP8080Z25CG12 - Left Disc
The bells need fitting to the discs (all parts supplied) and you need a 6NM Torque wrench & an E12 Star Socket (maybe E10) but its very simple and only takes about 15 minutes per disc.
Hi Ian
Kind regards
Ewen MacRae
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860111 (Fax)
marknjayne
- 1st Gear
Re: c7 discs fit?
Excellent thank you Ian
Re: c7 discs fit?
If anyone interested we have in stock DS2500 pads for RS6 C6 for £180 shipped.
http://www.jdl-brakes.com/ferodo-ds2500 ... 3133h.html
Re: c7 discs fit?
Have had C7 discs on for nearly 2 years now...
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
360 Modena (manual)
F430 Spider (F1)
marknjayne
- 1st Gear
Re: c7 discs fit?
really,any pics ,straight fit or modifications required ?993turbo wrote:Have had C7 discs on for nearly 2 years now...
Re: c7 discs fit?
front 6mm ''spacers'' on the calipper mounts.
rears nothing. Just dont run the pads too low as the discs are thinner.
360 Modena (manual)
F430 Spider (F1)
360 Modena (manual)
F430 Spider (F1)
Re: c7 discs fit?
So you space out the bolt with a 6mm washer if you will, interesting to know as they are cheaper than c6 items !
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
Re: c7 discs fit?
Well, you dont space out the bolt. You space out the calipper mounting to center the calipper on the the discs. The C7 discs have a 6mm diffrent offset.
360 Modena (manual)
F430 Spider (F1)
360 Modena (manual)
F430 Spider (F1)
TomRS
Re: c7 discs fit?
Basically where the bolt goes through the calliper mounting bracket on the hub you put a longer bolt and a 6mm spacer this move the calliper further out to take up the offset of the difference in the bell (i had to use 10mm titanium spacers when i ran my Tarox 16's)
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
Re: c7 discs fit?
Just remember to use longer bolts as the stock ones will have 6mm less thread available once you add a spacer which may not be enough for a secure fit!
Users browsing this forum: No registered users and 113 guests
