Has anyone fitted a Android unit in their c5
scatrat
Post by scatrat » Sun Mar 13, 2016 6:23 pm
I am baffles as to what size unit I can use to replace my rns d navigation plus.
Is it a 7 " unit.
Will I lose the mid display on my dash clocks.
My rs6 has no steering wheel controls.
Who can give me experienced advice please.
As I have a spare 7 inch head unit but concerned about plugs on the back.
Mɐʇʇ
Re: Has anyone fitted a Android unit in their c5
Post by Mɐʇʇ » Sun Mar 13, 2016 8:19 pm
Not android, but I fitted a pioneer SPH-DA120 so I could have apple carplay. Plugs at the back are simple, just needs a couple of adaptors. Plus a cage and adaptor for the front as well.
Yes, I did lose the display on the dash clocks.
scatrat
Post by scatrat » Sun Mar 13, 2016 8:40 pm
Thank you.
Have you got bose.
How did you get around the wiring on the bose setup
Gripper1
Post by Gripper1 » Mon Mar 14, 2016 4:00 am
What exactly do you want an Android for?
If you only need Bluetooth streaming and hands free calling there is options whilst retaining the original unit. I wanted to retain the factory look and also like the way it displays info on the DIS so had a box fitted in lieu of the 6 disc changer. I can stream my music to it and make/receive calls too.
Okay it may be a bit of a compromise in that it doesn't give full control of you music source, but using a Brodit active cradle and having the phone in an easy to access place I find it works well when I'm driving.
scatrat
Post by scatrat » Mon Mar 14, 2016 9:39 am
I have all of above too.
I like android and have in my other cars.
And my radio doesn't work
Mɐʇʇ
Post by Mɐʇʇ » Mon Mar 14, 2016 9:45 am
scatrat wrote:Thank you.
Have you got bose.
Depends on the headunit - but basically, I just got the connects2 adaptor lead that plugs the low level outputs from the headunit into the Bose amp. The acoustics of the Bose setup are a bit odd, so I had to add a fair bit to the bass on the equalisers in the headunit to even things out, but it sounds good now.
scatrat
Post by scatrat » Mon Mar 14, 2016 9:52 am
Cheers buddy.
I had same in my s6 but the music was always lowish
hubbly_bubbly
Post by hubbly_bubbly » Mon Mar 14, 2016 11:08 am
Im busy with a tablet install in my C5.
Just waiting on radio-steering wheel adapters from the UK then will finish up.
Have custom made the mounting fascia for the tablet.
docurley
Post by docurley » Mon Mar 28, 2016 12:18 am
I have an android in my RS4 got sick of the RNS-E
I have not made a great video but heres it working and no you don't need a keyboard at all
Something like this will do and you can update the firmware
http://www.ebay.co.uk/itm/AUTORADIO-DVD ... Swo6lWOg45
R5XVB
Post by R5XVB » Tue Apr 05, 2016 8:04 am
How do you find the DAB broadcast quality? I've heard that even with an auxiliary aerial the signal drops out more often than in comparison to a factory fitted DAB aerial which might be meshed into the windscreen for example.
Users browsing this forum: Google Adsense [Bot] and 110 guests
