Newbie spacesaver question
Markp
Post by Markp » Sun Sep 27, 2015 2:08 pm
First of many questions I suspect...
Tried searching on space saver spares and while some debate on here there seems to be no definitive answer, and dealer not much help.
I run 20 inch wheels on my car. Can I get a spacesaver to fit in the well of the boot that fit over the brakes and work rolling circumference wise?
doodlebug
Re: Newbie spacesaver question
Post by doodlebug » Sun Sep 27, 2015 2:29 pm
I don't believe you can.
Needmorespace
Post by Needmorespace » Sun Sep 27, 2015 8:18 pm
Needmorespace
Post by Needmorespace » Sun Sep 27, 2015 8:27 pm
Have been meaning to write up properly but didn't get round to it. I ordered a 20 inch space saver for the RS6. It fit in the boot fine once the load liner over the battery is removed. I got a new tool kit from ebay which sits on top of the battery below the wheel. The compressor and gunk fit under the wheel also but this is because I have RS Sports suspension plus which removes the aluminium air accumulator the wheel well for the standard air suspension. I ordered the plastic tray from ebay to cover the wheel up as per the standard spec for cars with the spare wheel. I was also nervous that it wouldn't fit. On such a practical and already heavy car I think the spare is a must for long trips. If I ever use it in anger I'll be careful on the throttle as its nearly half the width of the standard wheel.
Needmorespace
Post by Needmorespace » Sun Sep 27, 2015 8:39 pm
The wheel is a 145 60 R20. The toolkit that fits over the battery and under the wheels is part number 4G0 012 109. The new tray part number is 4G9 863 547
Needmorespace
Post by Needmorespace » Sun Sep 27, 2015 8:45 pm
Oh rolling radius is 2.6 percent different according to willtheyfit.com so hopefully fine
Markp
Post by Markp » Sun Sep 27, 2015 10:30 pm
Perfect. May I ask how much the whole set cost?
Needmorespace
Post by Needmorespace » Sun Sep 27, 2015 10:36 pm
All from eBay. Got wheel for 100ish delivered, toolkit from happyparts.de on eBay for £25 then tray cover for about £30
Nigelo2
Post by Nigelo2 » Sun Mar 06, 2016 2:42 pm
Any update on other alternatives? I'm not too happy with an 18mm difference in diameter despite speed and distance limit of the spacesaver. Still waiting for delivery in April but have specced with standard 20" and considering using a full size identical spare. Obviously that will have to live above the boot floor in a jacket which is a PITA but better then being stranded up continental S***'s Creek and having to wait for a new tyre.
Markp
Post by Markp » Sun Mar 06, 2016 3:06 pm
I bought a full sized spare which I keep at home - just put it in the car for long trips.
SteveH
Post by SteveH » Sun Mar 06, 2016 9:47 pm
The boot was so enormous, I used to carry a full size part-worn tyre. It paid dividends a couple of times on damaged side walls.
Present:...
Past:
Nigelo2
Post by Nigelo2 » Mon Mar 07, 2016 1:02 pm
Thanks Guys. What's the best place to source OEM rims?
wildbore
Post by wildbore » Mon Mar 07, 2016 2:49 pm
Needmorespace wrote:The wheel is a 145 60 R20. The toolkit that fits over the battery and under the wheels is part number 4G0 012 109. The new tray part number is 4G9 863 547
Can I just check, please: does the space saver use the same length wheel bolts as the alloy wheels?
RS6chris!
Post by RS6chris! » Mon Mar 07, 2016 4:07 pm
Good tip this one....what forums are all about :beerchug:
Not designed to do hundreds of miles but would get you home or somewhere safe whilst sorting a new tyre or repair.
Sooner go down this route than have to carry full sized wheel or tyre everywhere all the time.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Nigelo2
Post by Nigelo2 » Mon Mar 07, 2016 5:19 pm
Fair comment and each to their own but quite useless for my regular continental trips. I remain concerned about the 18mm difference in diameter which massively exceeds the max front to rear axle average tread depth difference Audi state as the limit presumably to protect the centre diff. Warranty issues could therefore arise
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 319 guests
