anyone knows where this noise come from? It sounds like a compressor...this high tone - making me crazy
Strange noise
- Audi-RS6-R
Strange noise
Hey guys...
Re: Strange noise
Hmm sounds a bit dentist drill. Could be turbo or secondary air pump
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
Re: Strange noise
That sounds like the turbo. Can you hear the high tone noise after you have changed to a new exhaust, I see you are selling the MTM exhaust in your signature?
- Audi-RS6-R
Re: Strange noise
@Ian...No - no noise changing after exhaust change on this tone...Turbos? Sure? Because the tone is exactly getting high & low with the rpm - don't matter if I drive or not.
Always the same...Yes - MTM is for selling...
@Kent...how to test if it's the sec air pump?
Sorry for my english
Re: Strange noise
Try turning off the AC. Difference?
- Audi-RS6-R
- Audi-RS6-R
Re: Strange noise
BTW.: My AC is always off...(winter)
But 10 min. ago I turn the AC on and the noise get louder...so what do you think?
Terminator
Re: Strange noise
Could be a worn bearing on the alternator or air con compressor.
The problem with leaving your air con off all the time during the winter is that the compressor seals can dry out causing leaks. Best to switch it on at least a couple of times a week.
Re: Strange noise
ThisTerminator wrote:Could be a worn bearing on the alternator or air con compressor.
People often turn their A/C off during winter as they think it only works when it's hot. A/C filters the air, even when using the heater, plus it stops the windscreen from fogging up by also drying the air. Fuel/power savings from not using it are negligible.
Current:
TT Mk1, 225 Quattro Misano Red, AmD map
Former:
RS6 Avant 2004, MRC Stage 1+, Bilstein Coilovers, Milltek & s/s downpipes
Saab 9000 Aero 1997, GT3071, Siemens Dekka 630s, Forge 50mm i/c, 3" downpipe, Maptun stainless header, Konis, Quaife lsd, a/c deleted, 4.05 ratio 'box, custom map, 470hp & 440lb/ft.
Saab 9-3 Aero Estate 2.8 v6 2006, 3" stainless downpipe & remap, 302hp & 380lb/ft.
Rouse Sport 304R Sapphire Cosworth 1990 (stock), 260hp & 300lb/ft.
Former:
- Audi-RS6-R
Re: Strange noise
So u think the noise is coming from my AC compressor? Any solution for that?
Terminator
Re: Strange noise
You need to take it to a competent, preferably Audi experienced mechanic to get the problem officially diagnosed.
It may be possible to rebuild the compressor if this is the problem, rather than have to buy a new one, which is not going to be cheap!
Quattro_RS6
Re: Strange noise
Try to diagnose the source of the noise with a "hear probe". It's a metal stick that you can hold on to different parts to hear the vibrations. Hopefully it's just your alternator, because dismantling the AC compressor means a lot of work..
I guess you have checked that the sound is not chaning when you turn the wheels? (i.e. the powersteering pump)
2013 Audi Q7 3.0 TDI - Family car
2008 Audi RS6 Avant V10 TFSI - Phantom black, ceramics, ACC, softclose, 21" MTM, MTM springs, MTM Cat back.
2003 VW Bora 1.9TDI Highline - Daily beater
1991 VW Golf cabriolet G60 & 1963 Ragtop T1 beetle, forever lasting project (started in 1998)
X 2007 Audi S8 V10 // 1998 Audi A6 2.5TDI Quattro // 2001 Audi RS4 MTM // 2000 Audi A6 2,7 BiTurbo Avant // 1996 Audi RS2 // 1991 Passat Syncro G60 Turbo
- Audi-RS6-R
Re: Strange noise
@Quattro_RS6 - the source is from the left side...and no changing sound by turning the wheels...
TomRS
Re: Strange noise
Sounds like either Alternator or tensioner/idler pulleys... i have a slight whine from my P/S pump but im not worried, changed the fluid and its quieter so when it gets really noisy i'll replace it.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
- Audi-RS6-R
Re: Strange noise
@TomRS - hope so you are right...but the noise is getting louder when I turn on the A/C :/
Users browsing this forum: CupraDine and 420 guests
