Fuse to Ecu keeps blowing
Evening all. Does anyone have any pointers as to why the 30amp fuse to the Ecu keeps blowing ?
It's happened twice in the last 3 or 4 weeks, big problem as the car just dies...
No damp carpets or foot wells, no steamy windows etc.
Thanks.
Thanks.
Re: Fuse to Ecu keeps blowing
The one in the scuttle?
Daytona RS6 Avant
Oh sorry no, the one on the main fuse board. I didn't know about the other one, good to know.
Have you checked the scuttle panel for water? Mine was almost full of water (blocked drain hole) and some of the main electrics where submerged. Luckily no fuses went.
Daytona RS6 Avant
Which number fuse?
Fuse number 29, I haven't hap a chance to check the scuttle yet
Lots of stuff coming off that fuse. It could be a short somewhere, or a fault in one of the following:
Ignition coils
Engine mounts
Camshaft timing valves
Not easy to determine which. You got any logged fault codes? Might help narrow it down.
My gut says a dodgy ignition coil.
Ignition coils
Engine mounts
Thanks for the help so far
I haven't had chance to check for codes yet today, but I do get the usual engine mount one.
I'll do a scan later today or tomorrow, although I don't have VCDS so how would I check the coil packs if no misfire shows up which it didn't the last time number 29 showed me the middle finger?
Cheese.
Cheese.
Problem is that fuse 29 takes the ECU out before it can store a fault, possibly. If you've got a faulty mount then I'd start by sorting that since it's on fuse 29 also. Maybe just unplug it for a while to see if that stops the fuse blowing.
The matter has been taken out of my hands now as the car left me stranded this morning, grrr, has anyone ever tried pushing one of these things!.
It blew the fuse every time the engine was started, four times, I had to pinch them from non essential items.
So just waiting for the car to be recovered by a local garage who I think might have difficulty in finding the cause.....
We shall see..
We shall see..
It's good that it's now doing it consistently. Will make trouble shooting much easier.
Agreed, I was kind of glad to be honest as it's the sort of problem you never know for sure if you've sorted or not.
Thanks for the help thus far although there may be a few more questions to come if the garage draws a blank.
Got the car back today, the problem turned out to be the wiring loom, not sure which part, had been tampered with and attached with cable ties allowing movement causing the wiring to rub through the covering and shorting to the bodywork.
Only cost a very reasonable £170 including recovery, so not too unhappy, could have been much worse.
Mind you spending the last couple of days driving around in the old Quattro ur was nice.
Thanks for the help and suggestions gents.
Nice you got it sorted
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Cool. Glad it was relatively painless.
How about a gratuitous UrCuntro pic? Any seconders?
Users browsing this forum: Bing [Bot] and 176 guests
