The warning came up yesterday that an indicator bulb had failed.
Turned out to be the near side wing mirror.
Now the thing is it still flashes when you unlock / lock the car but not as brightly as it should. Also when you first indicate you can see a feint flash in the mirror but then it stops and the warning comes up on the dash.
Anyone experienced this? I suppose it'll be a trip to the dealers....
Wing mirror indicator lamps
Re: Wing mirror indicator lamps
Drivers probably shot on the circuit. If in warranty you should be covered, if not then it's around £30 to replace.
nastro azzurro
Thanks Trups.
It's still in warranty (only 10 months old) but still really annoying that I now have to waste time getting it sorted!
