High pitched whirring / whistle noise with revs???
Lukai
Post by Lukai » Tue Feb 23, 2016 9:05 pm
Hi,
I've recently noticed a high pitched whirring type noise coming from the engine when its revved. It seems most noticeable when putting your foot down in 1st and second gear, it almost drowns out the exhaust note (without S button pressed) if I have the window down. I can't tell if its doing it all the time or not, I'm pretty sure it does it when not in gear too.
I know the engine does make some noise when revved, but it seems more exaggerated now. I half thought I was just being paranoid as it seems to drive fine. But then a friend asked if it was supercharged today after he heard me drive off from work which has made me worry again.
Anybody else had similar symptoms or have any idea what it might be?
bigrichw
Re: High pitched whirring / whistle noise with revs???
Post by bigrichw » Tue Feb 23, 2016 9:13 pm
The B7 engine does have a natural whirring sound, yes it's strange but I'd say it's perfectly normal.
Current Cars
A4 Cabriolet, Silver, Bose, Black Leather 3.0 V6
S4 4.2 V8, Silver, Symphony, Bose, Black / Beige Alcantara
Previous Cars
.:R32 MKIV 3DR Pearl Black (Awesome car), Lexus RX300, Lexus LS400, Mitsubishi Shogun Sport V6, Audi TT Roadster 225, Range Rover Vogue 4.6 V8, Mazda RX8 231, Peugeot 307 CC 180, Subaru Impreza WRX 2.5, BMW520i, Lexus IS200,Golf GTi MKV, Audi A4 1.9TDi 130
boba fett
Post by boba fett » Tue Feb 23, 2016 10:05 pm
bigrichw wrote:The B7 engine does have a natural whirring sound, yes it's strange but I'd say it's perfectly normal.
Get rid of it and get an M3, its a better car but you will miss the noise :audibash: :audibash: :audibash:
RossDagley
Post by RossDagley » Wed Feb 24, 2016 2:35 am
How many miles has the engine done?
Previously:
Lukai
Post by Lukai » Wed Feb 24, 2016 9:34 am
RossDagley wrote:How many miles has the engine done?
It's just ticked over 80,000
RossDagley
Post by RossDagley » Wed Feb 24, 2016 9:43 am
Might be worth posting a video here showing the noise.
The b7 does make a supercharger-esque noise and it can be quite audible especially when cold I found, but now you're tuned into it you may think it's worse than it actually is. It might be nothing.
I asked the mileage question as I wondered about the timing chains/tensioners but unlikely to be an issue on those miles. It's barely run in :)
Previously:
Post by bam_bam » Wed Feb 24, 2016 10:48 am
Do you have a wife/girlfriend in the passenger seat?
RossDagley
Post by RossDagley » Wed Feb 24, 2016 10:52 am
bam_bam wrote:Do you have a wife/girlfriend in the passenger seat?
That's a whine, not a whirr :biggrin3:
Previously:
TomRS
Post by TomRS » Wed Feb 24, 2016 11:15 am
My dads did this... we thought it was Aux belts/idler etc, got it all changed (it was actually due a change lots of play in bearings) but that hasn't cured the whine.
From hearing other B7's though they all make the same noise to conclusion is its normal and not to worry anymore! just put a louder exhaust on haha!
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Lukai
Post by Lukai » Thu Feb 25, 2016 8:20 pm
RossDagley wrote:Might be worth posting a video here showing the noise.
Yeah I think your right, hopefully its nothing to worry about. I've had a listen to a few on youtube and they sound similar, mine just seems louder than I remember it being.
I've uploaded a few audio clips to dropbox, have a listen and see if you think its normal:
https://www.dropbox.com/sh/exphjmvimb5p ... ByZMa?dl=0
asifg
Post by asifg » Thu Feb 25, 2016 8:24 pm
The clearest clip for me was at Standstill and it's the same as mine. My car has been to Audi, MRC and TTS in the last year and no-one has said that there's an issue so I don't think you have anything to worry about judging by what I could hear
audi_do_dat_den
Post by audi_do_dat_den » Thu Feb 25, 2016 9:27 pm
I cant hear an awful lot wrong with that to be honest..... the straight cut gears on the auxiliary drives of the FSI RS4 engines make a lot of whine at all speeds naturally.
You could turn off the air-con just to eliminate that.
Another possible thing to check is the alternator and its belt tensioner for a noisy bearing, but that will require getting the undertray off and ideally using a mechanics stethoscope on it.
If it is a noisy bearing, it will get louder and progressively more pronounced well before it fails, so just try and monitor it.
Pistolpete2543
Post by Pistolpete2543 » Fri Feb 26, 2016 11:07 am
Sounds perfectly normal to me, music to my ears.
Lukai
Post by Lukai » Wed Mar 02, 2016 7:03 pm
Phew, sounds like I was worrying over nothing then. Thanks for all the replies, I'll keep an ear out for it getting louder but in the meantime I can just enjoy the noise :rocker:
