auto-electrician needed in west mids, warwickshire area
folks need a recommendation for a good auto-electrician - got an issue with battery losing charge so need some fault finding/diagnostic work etc.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
TomRS
Re: auto-electrician needed in west mids, warwickshire area
Not your alternator is it? common fault(ish) on c6's... just check charge voltage with a multimeter should be 14v(ish usually a bit more) when running and ~12v when not.rtd wrote:folks need a recommendation for a good auto-electrician - got an issue with battery losing charge so need some fault finding/diagnostic work etc.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
I don't have one Tom, but will seek one out thanks for the tip mate.TomRS wrote:Not your alternator is it? common fault(ish) on c6's... just check charge voltage with a multimeter should be 14v(ish usually a bit more) when running and ~12v when not.rtd wrote:folks need a recommendation for a good auto-electrician - got an issue with battery losing charge so need some fault finding/diagnostic work etc.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
TomRS
Most places sell them, stick in onto voltage check your resting voltage is around 11.5-12.5v anything in that will be fine (it'll be lower the longer the car has been stood but should go no lower than 11.5v really)rtd wrote:I don't have one Tom, but will seek one out thanks for the tip mate.TomRS wrote:Not your alternator is it? common fault(ish) on c6's... just check charge voltage with a multimeter should be 14v(ish usually a bit more) when running and ~12v when not.rtd wrote:folks need a recommendation for a good auto-electrician - got an issue with battery losing charge so need some fault finding/diagnostic work etc.
Then fire up the car and charge voltage should be around 14v - 14.6v anything in that area.
If not then i'd suspect alternator at fault! like i said common issue on our C6's mines already had one replaced before i got it, and there's a a fair few others that have had the same bother!
If charge is fine then it could be a simple case of a aging battery in need or replacement.
oh OK, maybe I might go buy one. battery is brand new OEM fitted last Nov Tom.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
