My 07 Avant has auto lights but no auto-wipers. I do have the auto-dimming rear view mirror.
Looking through various forums, it seems as though they specced together.
Should I have auto-wipers? Looks like I have some weird hybrid spec
Auto-Lights but no Auto-Wipers
- daytonamart
- 5th Gear
Re: Auto-Lights but no Auto-Wipers
That is strange, I thought they came together.
Is it possible someone has turned them off with VCDS? my current A3 has auto lights and wipers and you disable the wipers in the vehicle settings.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
- Surrey Sam
Agree with Mart, they should all come together.
If fitted you should have a sensitivity dial on the face of the wiper stalk, you then click the wiper stalk up one position and leave it there to utilise the function. If you have a non OEM windscreen fitted, then it can affect the auto wipers. I've found that they become less sensitive to the rain on various cars, so now only use genuine screens.
- PetrolDave
You can adjust the auto wiper sensitivity with VCDS to work better with non-OEM screens http://wiki.ross-tech.com/wiki/index.ph ... _Window.29
- Surrey Sam
Any idea how to Dave, I assume that it's channel 22 and you lower the % ?PetrolDave wrote:You can adjust the auto wiper sensitivity with VCDS to work better with non-OEM screens http://wiki.ross-tech.com/wiki/index.ph ... _Window.29
- PetrolDave
That would be my guess too.Surrey Sam wrote:Any idea how to Dave, I assume that it's channel 22 and you lower the % ?PetrolDave wrote:You can adjust the auto wiper sensitivity with VCDS to work better with non-OEM screens http://wiki.ross-tech.com/wiki/index.ph ... _Window.29
I had the same problem but my solution was a simple one................I changed the headlight washer pump - bingo.
RS4 B7 Phantom Black - Super Sprint X-Pipe - LED Conversion
Users browsing this forum: No registered users and 1601 guests
